Author Topic: Any pointers on mounting my ATC front fender brace.  (Read 4082 times)
Offline pantera1975
« on: July 21, 2013, 09:16:53 AM »
What has anyone else used for mounting the brace to the plastic fender part? Did anyone use bushings to space it or have just as good of luck bolting the fender to the brace? Thanks
« Last Edit: July 21, 2013, 09:31:58 AM by pantera1975 »
Offline Black Sheep
Any ointers on mounting my ATC front fender brace.
« Reply #1 on: July 21, 2013, 10:57:27 AM »
I just bolted mine directly and used a fender washer on the underside.
Offline pantera1975
« Reply #2 on: July 21, 2013, 09:53:53 PM »
I thought I red somewhere in the past the fender is prone to cracking. Thanks
Offline 2strokesforever
« Reply #3 on: July 21, 2013, 11:31:38 PM »
I used small rubber bushings underneath the fender and on top of the fender where the metal touches the plastic on my ATC350X and that what I didnt have to tighten it all the way down and it has been fine for 3 years now with no cracks.
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline Black Sheep
« Reply #4 on: July 21, 2013, 11:54:45 PM »
Quote from: pantera1975;4971
I ran mine from 1985-2002 and never had a problem. I could even scan the Hondaline insructions that come with them and that is how they show to do it. I also had the fender extension on it that added stress, especialy with mud underneath it.  Not saying it would hurt to use a rubber bushing either.
Taken in '02'
I'd still have this ATC if my ex-wife did not steal it :mad: :mad: :mad:
« Last Edit: July 22, 2013, 12:10:07 AM by Black Sheep »
