Workshop
Engine and Bottom End
01 cr ignition specs
Topic: 01 cr ignition specs (Read 3582 times)
compton5
May 08, 2015, 06:44:01 PM »
Anyone have test specs on a 01 cr ignition quad breaks up under a load change from 38 tmx to a 38as changed jetting on both and still has breaking up some times low end sometimes up top were ever it wants two
dem3500
May 08, 2015, 08:58:44 PM »
I don't know exactly what your asking for. Your statement is pretty general. Look here for timing curves.
http://trx250r.org/threads/96-Ign-maps
Other than that check grounds and make sure your stator plate is tight and pickup is clean.
udontknowme
May 09, 2015, 11:21:16 AM »
ive got the '02-'04 cr250 service manual but i dont know if it would use the same ign specs, might be able to find a free manual online somewhere
compton5
May 09, 2015, 11:30:30 AM »
I think I found my issue the one reed on vforce came loose and a dime size piece is missing out of the corner
compton5
May 09, 2015, 11:22:14 PM »
Thanks for the info during diagnosis I found umberto fuel oil mix in air box boot check ed the reeds and sure enought broken reed replaced it and it's running the way a r should to bad Im the owner of 38as now
Workshop
