Author Topic: 77.5 mm bore 330 Pro-X thoughts  (Read 3045 times)
Offline atvcrazy
« on: May 22, 2015, 02:57:07 PM »
Have a 77 mm bore Pro-X 330 that has been running for 4-5 years and is probably due for a piston.  Motor is apart for trans issues so going through the motor.
77.5 mm is the final bore on the 330, sleeve seems a bit thin at 77.5 but there's a piston size for it so going to do it.
Has anyone ever gone out that far bore wise and had problems?
anyone's experience would be great.
« Reply #1 on: May 22, 2015, 03:48:04 PM »
If its out of tolerance then bore it, if it is in tolerance then hone it. Shouldn't have any issues at 77.5
Best regards
-Jason
Offline atvcrazy
« Reply #2 on: May 22, 2015, 04:46:49 PM »
thanks
« Reply #3 on: May 22, 2015, 08:12:52 PM »
should of had it plated on day one
