Author Topic: having spark problems ?  (Read 3202 times)
Offline Outlaw1972
« on: August 29, 2015, 08:05:50 PM »
Hello I am at a loss here, I bought another 86r that has a ct310 cylinder with a bad piston. I have all of that fixed but I think the reason it burnt up was because of a ing problem. I got it put all back together this morning and I checked to see if I had fire before trying to start with the plug out and it did, but had to kick it really hard-fast. So I put the plug in and go to bust it off for the first time and it kicks back like nothing I've ever seen ! I mean had to put a riding boot on. I took the stator cover off and pulled the fly wheel, it is new and the stator and the pick up is, it has a red cdi box on it so I took the cdi box off of my other r that runs good. It still has all of the original elect parts on it, I put that cdi box on it and it does not have any spark with it ? but does not kick back because it is not firing. I assume it is firing to soon or something of that sort causing it to kick back so bad, but I don't understand why it has no fire with the other cdi that I know is good. It does not have a adjustable timing plate and the pick up is in the stock location I even tried the other coil to. Could some one please help me, tell me what to try from here. Thanks for your help.
Offline jfwyatt1
« Reply #1 on: August 29, 2015, 09:03:27 PM »
does the stator look oem? if not thats probably part of your problem also dont use aftermarket CDIs they have a reputation for problems. might check the wiring to see if anyone has messed with it. i had a ricks stator once that would only fire with 1 specific cdi i had wouldnt with another even though i new both CDIs were good as they worked fine on another bike. swap the stator next if you cant find any wiring problems.
Offline Outlaw1972
« Reply #2 on: August 29, 2015, 11:23:01 PM »
Ok I will try swapping the stators out next, thank you for the help
