Author Topic: Scratched Hinson racing quick change clutch cover, anyway to repair?  (Read 4697 times)
Offline turkey_drag
I know this doesn't do a lot for me without pictures, but bear with me. I have an original Hinson quick change. It has the polished plate and has the typical kick starter rash that a lot of them were plagued by. I know that CT has started reproducing the covers and the plates, but the waiting list to get one is like trying to get a new heart or kidney. That and I would like to keep my Hinson one if all possible. Does anyone think it would be possible to "lightly" weld up the scratches in it, machine/sand down whats on top, then go back into the letters and engrave them again with a dremel. I say lightly, meaning not pour the heat to it to avoid warping the plate.
« Reply #1 on: December 21, 2015, 02:11:49 PM »
CT is making a lot of these and offer both the CT Racing AND Hinson Racing quick change cover plates.  You'll need to buy a full cover to get a the quickchange plate OR ask Roxanne to put you on a list for just the quickchange cover (which last I heard, she was doing in the coming months).  So - not too hard to get if you ask me.  In the last month, I've bought a 2 BNIB cover plates (one black, one red) and a polished side cover quick change from CT.
« Reply #2 on: December 21, 2015, 03:25:40 PM »
I do know of a new polished cover plate for $135 shipped with new bolts and o-ring.  PM me if you're interested.
« Reply #3 on: December 21, 2015, 11:23:59 PM »
Sure you could weld and sand it down. It's going to take awhile and lots of patients. Good luck. Show us your progress
« Reply #4 on: December 22, 2015, 10:11:34 AM »
sell it and put one of those sexy clear cranked up gear ones on it.
Offline turkey_drag
« Reply #5 on: December 22, 2015, 10:22:16 AM »
I kinda just figured tig it up and sand it back down. I plan on powdercoating it blue anyways, then highlighting the letters with silver.
« Reply #6 on: December 22, 2015, 11:14:39 AM »
Quote from: JesseA420;62176
I thought they just offered the clear & colored ones for ESR quick change covers.  Do they offer then for the traditional Hinson/CT/Duncan/Rath/T&T/etc.?
« Reply #7 on: December 22, 2015, 12:58:09 PM »
no i meant sell the whole thing and replace with esr and cranked up gear lexan window :)
Offline wilkin250r
« Reply #8 on: December 25, 2015, 06:11:45 PM »
It's aluminum, right?  I'd probably recommend BRAZING over welding.
Brazing is typically done with a torch, not an arc, and generally done at much lower heat.  And because you don't use an arc, you don't eat into the base material, so there's no risk of any blow-through.
https://www.youtube.com/watch?v=TZ5sD9hQTyw
« Reply #9 on: December 27, 2015, 04:51:38 AM »
since its thin aluminum plate, it will likely warp.  you would need a heat sink of some sort to mitigate the warping; and even then it isn't fullproof.
but, if you decide to weld, you will need it stress relieved.  stress relieving should allow it to go back to flat...  and again, it takes an experienced individual to do this correctly.  the properties of the aluminum will have a baring on the stress relieving procedure.  i.e. 6061; 6061 T?; 7075; 3003 and etc.  the T (tempering) will be an important factor here.
Offline turkey_drag
« Reply #10 on: December 27, 2015, 08:52:56 PM »
I scored another Hinson cover thanks to [MENTION=87]havinnoj[/MENTION]. Im gonna keep the scratched one for a spare, Ive heard jb weld can be used as a filler for powder coat. I may try building it up, and then sanding it down and powder coating the whole piece.
