Author Topic: 48 lectron fitment  (Read 5320 times)
Offline fast350r
48 lectron fitment
« on: December 24, 2015, 08:49:34 AM »
I got a 48mm lectron with billet bowl for my puma , and i cant get the darn thing to fit right? I have the upp puma in take and it fits slighly slanted clockwise not to mention their is no way to with my air filter set up : (
Any suggestions on intake set up or manifold?
Will the carb run right slanted?
Shearer 431 puma
48 lectron fitment
« Reply #1 on: December 24, 2015, 09:40:58 AM »
Is it the Billet bowl with the corner notched out?
I ran a 44 on my Sphinx with the regular clear bowl and UPP intake. My intake was shortened a little for other reasons but it would fit. This is in a stock frame and it is a tight fit.
On the Puma there is a 52 with the billet bowl and it clears the cases but no issue with frame as it is in aftermarket frame.
Offline fast350r
48 lectron fitment
« Reply #2 on: December 24, 2015, 10:04:24 AM »
no the bowl is not notched out? the main problem im having is the carb bell faces the rear shock and leave a bad curve for the intake
Shearer 431 puma
Offline Morse250r
48 lectron fitment
« Reply #3 on: December 24, 2015, 10:35:46 AM »
I had that prob on a 48 on the pro x.  I had an aluminum intake made and changed the angle to allow air filter to clear. Hard in stock type frames
88 rb racing duner
Trx 70\'s
Atc 125
Offline fast350r
48 lectron fitment
« Reply #4 on: December 24, 2015, 10:50:26 AM »
so I need a custom made air filter system?
Shearer 431 puma
Offline Saber569r
48 lectron fitment
« Reply #5 on: December 26, 2015, 07:12:23 PM »
Packard is the way to go. The cocs is garbage. Just like him.
Offline Morse250r
48 lectron fitment
« Reply #6 on: December 27, 2015, 02:57:35 PM »
Well it's what I had to do to get it to work. On my drag frames I made sure I had enough room there and now I run just a reg upp
88 rb racing duner
Trx 70\'s
Atc 125
Offline fast350r
48 lectron fitment
« Reply #7 on: January 06, 2016, 08:58:23 PM »
Problems solved , jared suggested id boil and stretch the stock cr500 boot and it worked 48mm slipped right on , and it gave back the correct angle . I added an led to finish it of.
Shearer 431 puma
Offline fast350r
48 lectron fitment
« Reply #8 on: January 06, 2016, 10:37:04 PM »
Shearer 431 puma
