Author Topic: atc 350 engine  (Read 5715 times)
Offline TRXDAN
atc 350 engine
« on: January 01, 2016, 11:34:07 PM »
Ok guys im picking up a 1985 atc 250r with a 350 kit and a 5 mil crank.im wanting to put the motor in my 89 trx250r..i know it will bolt in. What doni do about the wiring?
Offline jwraymond6
atc 350 engine
« Reply #1 on: January 01, 2016, 11:47:06 PM »
im not an expert but I think the wiring is the same
Offline atv fan 28
atc 350 engine
« Reply #2 on: January 02, 2016, 12:00:42 AM »
I believe the connections between those 2 years are different
atc 350 engine
« Reply #3 on: January 02, 2016, 12:08:40 AM »
You'll need to swap the stator between the two bikes.
atc 350 engine
« Reply #4 on: January 02, 2016, 12:13:41 AM »
Quote from: Skeans1;62748
This, 89 has different connectors.
atc 350 engine
« Reply #5 on: January 02, 2016, 06:50:47 PM »
Jared maybe send him a link for those connectors you used on my stator wiring.... Very clean and also weather tight.
Offline Anthony0327
atc 350 engine
« Reply #6 on: January 16, 2016, 07:11:46 AM »
just change out stator and flywheel. The Atc setup was a little different. The plugs coming from the stator are different in 89 than any other year. All bolt right up no problem.
Offline pantera1975
atc 350 engine
« Reply #7 on: February 05, 2016, 01:14:19 AM »
Or you can have Michal systma make you a new harnss
Sent from my SM-N920R4 using Tapatalk
atc 350 engine
« Reply #8 on: February 05, 2016, 05:03:37 AM »
Quote from: pantera1975;64156
Who is this. He can make a 89 harness.
Offline christph
atc 350 engine
« Reply #9 on: February 05, 2016, 05:35:52 AM »
Why not transfer the 85 CDI and wiring to the 89?  When I put my 86 ATC engine in my 88 TRX for a while, I also replaced the 88 CDI with the 86.  The 86 engine didn't want to run with the 88 CDI because it had more advanced timing by 2 degrees.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
