Author Topic: KTM Rod Bottom End Help  (Read 4823 times)
Offline teddy250r
« on: January 10, 2016, 05:52:03 PM »
Hey there, some of you might recognize me from some of the other sites, I recognize a lot of names in my searches....hope everyone is well great site.
I have a nice fresh bottom end with a stock stroke crank with a KTM 132mm rod that I'd like to build a play bike with.
I'd like to do a budget ESR 330/350 kit with an in frame pipe.
What would I have to do to make this work as the Ktm rod is 132mm long and a stock long rod is 130.3mm? Thank you!
Teddy
« Reply #1 on: January 10, 2016, 06:15:51 PM »
[MENTION=1648]teddy250r[/MENTION] - I'm not going to comment on the rod question but literally a few days ago I stumbled on a QOTM thread from the other site with your bike and mine and I almost put up a post here asking if anyone knew where you went!  So on that note - are you still riding / racing (you had a 350/370 that you ran on dirt/sand tracks back East from what I remember)?
Offline atv fan 28
« Reply #2 on: January 10, 2016, 07:05:31 PM »
Pete@Hybrid is in the process of building me a 6mil Sphynx.  He  suggested i swap the OEM rod out with a KTM rod. I'm sure he will have to use a custom spacer plate. But you might give him a call and pick his brain.
Offline teddy250r
« Reply #3 on: January 10, 2016, 07:24:48 PM »
Quote from: havinnoj;63090
Yes, I still have that bike..it's currently in peices, this is the bottom end for that bike. It was a 370 stroker that went boom and then a Packard 350 stock stroke. I haven't raced in a few years (babies), but I have decided to throw this bike back together and play around with it a little...I kept everything but the Packard cylinder and pipe so that's why I'm going with a cheap ESR type build with an in frame most likely.
Hope you are well, I always loved your bike from back in the planetsand days. You still have it?
Teddy
Offline teddy250r
« Reply #4 on: January 10, 2016, 07:28:42 PM »
Quote from: atv fan 28;63091
I might do that, I did save his number.
That what my thoughts are, likely will have to customize a spacer plate to compensate for the difference rod length.
Offline dp250r
« Reply #5 on: January 11, 2016, 08:07:10 AM »
Welcome Teddy.I havent seen you in awhile.I dont think Adirondack had many races this past year.Joe Pate came out in 2014 and raced a few drags.   Darryl
Offline hontrx265r
« Reply #6 on: January 11, 2016, 09:59:46 AM »
Its basically just going to be a spacer plate setup for the extra rod lemgth or a set of custom tall deck esr cases would do the trick as well
« Reply #7 on: January 11, 2016, 11:48:25 AM »
Quote from: hontrx265r;63103
Yep, a 2mm spacer is what I used with my stock stroke Puma on OEM cases using the KTM rod.
Offline jadleybray
« Reply #8 on: January 11, 2016, 12:03:53 PM »
I think Pumashine cut the spacer I used on my ESR 5mill 370 with KTM rod too.
