Author Topic: 363 sphinx Preproduction cylinder  (Read 3375 times)
Offline trx363_Hunt
« on: February 09, 2016, 10:31:19 PM »
Ok guys I've done some footwork on this motor and finally talked to Nate McCoy and sent him pictures of the cylinder. He said it is a preproduction sphinx cylinder and that he isn't positive on who did the work but said he could have done it. I'm wanting to sell to get a puma. This is all I know of the engine as of now.
Replated by millennium with about 10 hrs on it. At the same time it had new crank bearings and seals put in. Also esr 78mm piston. It has a hot rods crank +4. The exhaust has been ported but not intake. Stock tranny as far as I know with stock basket. Also has stock ignition which is about junk. Has a 44mm lectron carb single power jet and Packard bowl, vforce 3 reeds, esr intake, esr trx11 center mount pipe. One case saver tab is broke. Motor is setup for race fuel. The intake is drilled for a vacuum line. I'll provide any pictures if possible. I'll try getting some of carb and exhaust tomorrow.
2700 for everything.
Text 2605254209
Sent from my LG-H810 using Tapatalk
Offline trx363_Hunt
« Reply #1 on: February 10, 2016, 07:41:41 PM »
Offline kb250r
« Reply #2 on: February 10, 2016, 10:45:20 PM »
How much for the pipe?
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline trx363_Hunt
« Reply #3 on: February 10, 2016, 10:49:50 PM »
I'm wanting to sell everything together. If someone buys the motor and doesn't want the carb and pipe then I'll sell those.
Offline trx363_Hunt
« Reply #4 on: February 15, 2016, 10:16:49 AM »
Bump.
Offline trx363_Hunt
« Reply #5 on: March 22, 2016, 09:31:24 AM »
Sold
