Author Topic: New light coil setup  (Read 3790 times)
Offline d-rock
« on: March 04, 2016, 05:49:06 PM »
Has anyone tried the cr250 ignition with lighting coil from service Honda?
I got this off of there site.
2000-2001 CR250 , 130 watt lighting kits with Vortex 10x map CDI
also available currently! $953.19
The Vortex 10x map CDI's are programmable,and the programming
software is available directly through Vortex.
The Vortex CDI can be purchased separately: $535.95
Thanks Derek.
Offline bmc1025
« Reply #1 on: March 04, 2016, 11:26:03 PM »
I would recomend using the stock stator as a charging coil with a trail tech regulator and battery. Then you can use an MSD 4217. You will have to make a custom map. There are plenty of pictures on here and other sites where people have plotted out the mapping of a few different cr and trx CDIs
Offline d-rock
« Reply #2 on: March 05, 2016, 11:50:56 AM »
I have a cr250 ignition now, just looking for a better lighting option.
Offline dem3500
« Reply #3 on: March 05, 2016, 02:59:47 PM »
Some day when I get the time I'm going to mount a small motorcycle battery and 6" led light bar. It will run off the battery for more than 12 hrs straight without a recharge.
