Author Topic: Confused about 89 engine mounts on chassis  (Read 2613 times)
Offline mudbogger
« on: March 13, 2016, 09:46:28 AM »
Hi, I have my 89 trx 250r frame on the table, mounted the engine in it, and there appears to be a engine mount missing on the rear bottom by the swinger. Is this mount only used on the 86-88 models? I do not have another mount here in my labeled packages so if it was supposed to be on the trx, it was not when I took it apart several years back. I see on ebay a "half moon" style engine mount that appears to me the swinger bolt go through, my trx does not seem to utilize this mount, am I wrong that it does not belong on my 89?
Here is the mount I am speaking of-
http://www.ebay.com/itm/Honda-250R-OEM-Rear-Engine-Mount-TRX-TRX250R-Motor-ATC-ATC250R-/351660448438?hash=item51e0989ab6:g:XS0AAOSw~OVWy76R&vxp=mtr
FOOTNOTE-I do not have my manual, lost it some years back and have 1 ordered, I went and downloaded the online manual and it appears this year does not utilize this mount to the engine, but I am unsure- so please bear with me, newbie here.
« Last Edit: March 13, 2016, 09:49:09 AM by mudbogger »
« Reply #1 on: March 13, 2016, 10:00:08 AM »
The '88-'89's do not use the lower back mount hole on the engine. Some gusset kits add it though. The "half-moon" piece is for '86-'87 only. the later model swingers are solid from side to side.
Offline mudbogger
« Reply #2 on: March 13, 2016, 07:40:46 PM »
Ok thanks much. Now need spindles and front mounts, bolts for the mounts as well.:nevreness:
« Reply #3 on: March 14, 2016, 10:04:09 AM »
it doesnt hurt to pick up the tabs from a gusset kit and weld them in, to utilize those mounts on a 88-89 frame, or if u have the resources make some up.
