Author Topic: Extended brake lines  (Read 7552 times)
Offline cww909
« on: March 23, 2016, 02:04:19 PM »
So I just got my +3 JD LT arms and need extended brake lines. Any preference with anyone?  I've seen the cheap ones from eBay, Streamline, Galfer or Lonestar?  All brake components are stock.
Online Tbone07
« Reply #1 on: March 23, 2016, 02:36:05 PM »
Most of the brands are similar. I'd opt for the T connector version though, not the dedicated lines
« Reply #2 on: March 23, 2016, 02:55:13 PM »
Quote from: Tbone07;65852
X2. I think the T split is a cleaner install but have also ran dual dedicated lines for years without issue.
Offline cww909
« Reply #3 on: March 23, 2016, 03:02:27 PM »
Awesome thanks guys.  Clean is always better in my mind.
Offline jadleybray
« Reply #4 on: March 23, 2016, 03:08:06 PM »
Apex Brake Lines - good quality, selection of colors and very reasonably priced.  I bought a 90" for 70$ I think.
Online Tbone07
« Reply #5 on: March 23, 2016, 04:32:59 PM »
Quote from: cww909;65856
Quote from: havinnoj;65855
I have dedicated right now too, but just bought the T connector version. The dedicated lines are annoying and tough to route
Offline cww909
« Reply #6 on: March 23, 2016, 05:31:07 PM »
Do you guys recommend buying clamps for the arms or just zip tie and some rubber or something like that
Offline jadleybray
« Reply #7 on: March 24, 2016, 01:57:19 AM »
Just your preference on mounting, I utilize fancy zipties
Offline cww909
« Reply #8 on: March 24, 2016, 02:08:43 AM »
I got plenty of those haha. Thanks
Online Tbone07
« Reply #9 on: March 24, 2016, 09:03:05 AM »
I use zipties and clear hose right now. But it likes to scratch up the chrome on my upper a-arms so i'll be switching to rubber mounted clamps
Offline cww909
« Reply #10 on: March 24, 2016, 09:21:58 AM »
I'll probably find some rubber to buffer between line and the arm so it doesn't rub
« Reply #11 on: March 24, 2016, 10:25:30 AM »
Quote from: cww909;65851
All of those brands that you mentioned make quality parts. I run Streamline myself. While you don't have to, I would pay the little extra and get some brake line clamps/holders. They look good and they won't wear on lines like zip ties could. If you're gonna do zipties, at least do do the double ziptie method and not ziptie them directly to the arm using one tie. I also agree on using the T connector. It's personal preference, but I like the look better.
« Reply #12 on: March 24, 2016, 12:06:25 PM »
Quote from: rablack21;65886
Great point.  I've always ran clamps but a couple years ago I picked up the swivel-type clamps and absolutely love them.  I got mine from Cascade Innovations but there are probably other vendors:  Cascade Innovations Brake Line Holders
« Reply #13 on: March 24, 2016, 12:26:13 PM »
Quote from: havinnoj;65890
Ok, that is pretty dang cool! I may consider getting some of those. Me likey! Do they just pivot as the suspension flexes? Or do they swivel and then lock tight into whatever angle that you desire?
« Reply #14 on: March 24, 2016, 12:54:04 PM »
Quote from: rablack21;65892
Yup they are trick and function great!  They swivel / pivot as suspension flexes and/or as wheels turn.  The rubber grommet around the brake line allows for just a bit of brake line movement which is nice. But you could obviously stiffen or loosen that up to your liking depending on grommet thickness.
