Author Topic: "Break-In" your newly rebuilt Engine  (Read 3059 times)
« on: July 31, 2013, 11:55:21 AM »
link to page http://www.sacoriver.net/~red/breakin.html
 The purpose of the "break-in" procedure is to  GRADUALLY wear down the "high spots" on components such as rings, piston  skirts, cylinder walls, bearings and races, etc. after a motor is  fitted with new items.   ALL machined parts are imperfect to a certain  degree and therefore have "high" and "low" areas which must be mated to  those that they roll or rub against to achieve a good running fit.    Problems can arise however in the process because the mere act of  "rubbing down" the high spots creates abnormally high friction.    Friction creates heat.   Heat creates expansion.   Expansion reduces  running clearances and increases friction.   More friction, more heat,  more expansion...   Pretty soon you can see that you are rubbing off  MORE than high spots on each part resulting in premature part wear (LOW  spots).   This is what happens when a motor is broken in too  aggressively.   You end up with a motor that, at the very least, has  abnormally LARGE running clearances throughout.  Thus you now have an  unnecessarily shortened remaining life for your "new" motor accompanied  by reduced performance.   If the motor is really abused during early  "new life" running, the tight initial clearances may get closed up  completely due to heat and expansion and the rotating or reciprocating  parts will SEIZE.   So how to control this "running in and mating" of  moving parts becomes the question...
     First, before you even start the motor for the first time,  do a "cranking pressure" compression test with a good quality,  screw-into-the-spark-plug-hole type compression gage.   Ignition off,  fuel off, throttle held WIDE OPEN.   Kick, pull-rope or cycle the  electric starter until the gage reaches its' highest reading and stays  there.   Note the reading and record it.   Don't expect a real high  number because the rings and cylinder are not mated yet, but you should  see at least 100 psi, sometimes much higher depending on the planned  compression ratio, port timing (or camshaft profile if it's a four  stroke), etc..   Generally speaking, with fuel, air, spark at  approximately the correct time, 100 psi gage pressure and exhaust, the  motor will run.
     I prefer to break-in motors on a petroleum based oil and  then switch to a synthetic afterwards (if it's to be done at all).    There's lots of opinions on this...... for better or worse, that's  mine.   My feelings are that "too slippery" an oil will slow down the  break-in process too much and I've even seen 600X cross hatched  cylinders, chrome and Nikasil bores where the rings never seated and we  attributed it to synthetic oils during break-in.   If it's a two stroke,  you can add a bit of extra pre-mix oil to the fuel, set the oil pump at  a slightly higher than normal base setting, or both for the first tank  of fuel, but I'd use a petroleum based oil.
     OK.   Start the motor and allow it to run at approximately  1500 rpm or so.   Shut the choke off absolutely ASAP!   The excess fuel  that the choke supplies can wash the oil film off the cylinder walls and  overheat the ring faces quickly, especially in a four stroke.   ALWAYS  shut the choke off ASAP on ANY motor for this same reason.   NEVER let a  motor run for long periods with the choke on to warm it up.  NEVER  ride, drive, fly or place under load any motor driven device with the  choke on.   It is a quick route to early death for the rings.
     Check immediately for oil and compression leaks around the  various gasket sealing locations.   ANY LEAKS should be fixed  immediately, especially head, base or exhaust gasket areas.   If there  are none, hold your hand against the cylinder and GENTLY vary the engine  speed in neutral between approximately 1500 and 2500 rpm.   DO NOT OVER  REV!   There is no "load" on the engine and over revving is very tough  on crankshaft, bearings, etc.!   When the engine is warm enough to be  uncomfortable on your hand, shut it off.   Again check for any leaks.    Now let the motor cool down to COLD.  THEN, carefully re-torque the  head(s) at this time.
     Now you're ready for your first ride/drive/flight/whatever.    Start the motor and warm-up gently exactly as before.   When the motor  is uncomfortably warm on your hand, stab her in gear and gently  accelerate through each gear using about 1/3 to 1/2 throttle as a shift  point.   DO NOT BOG or LUG the motor.   DO NOT "cruise" at a steady rpm.    Vary the engine speed up and down at all times.   DO NOT OVER REV  either!   When you reach top gear immediately slow down and ride back to  your origin doing the same thing.   Limit your initial ride time to 5  to 10 minutes maximum, all the while touching the cylinder frequently  with your hand to sense drastic overheating.   ANY signs of excessive  heating or abnormal engine noises require immediate SHUT DOWN and  investigation/cure of the culprit.   If in doubt, DO NOT ride/drive/fly  back to the garage and then shut it off...  TOW it back!   When you're  done with the initial ride, let it cool down to COLD again.
     Continue this procedure gradually extending the running time  to 10 minutes, then 15 minutes, etc..   You can also gradually get a  bit more aggressive with throttle application (slightly bigger  "handfuls/footfuls" of throttle).   Speed up, slow down, constantly  varying throttle position and going up and down through the gears.    Steady cruising at one engine speed or lugging the motor below its'  powerband in a higher gear can cause overheating during break-in...   AVOID BOTH!   Don't worry so much about too high an rpm as VARYING the  rpm.   Bursts of throttle allow heating and mild expansion which in turn  shaves off those high spots while deceleration allows slight cooling  and contraction.   Stay away from long hills, carrying a passenger or  heavy loads during break-in.
     After about an hour total riding/driving/flying time has  accumulated, recheck cranking compression.   As the rings seat, you will  see the readings come up and you will also notice improvements in power  delivery.   Break-in is essentially complete when the readings peak and  no longer get higher as more riding time accumulates.   For a two  stroke, this is typically one to three hours break-in time.
     A four stroke has a superior oiling system and therefore  breaks in more slowly.   Two to five hundred miles is frequently  required to completely break-in a four stroke.   For a closely toleranced street four stroke it often takes 1000 to 1500 miles or even  more!   I dump the oil and filter in a four stroke after the first 75  miles, again at 200 miles, 500 miles, 1000 miles and each 1500 miles  thereafter on a street engine.   Off road and competition four strokes  get fresh oil and filter every one hundred to four hundred miles with  me, depending on how hard their running life is after break-in.   The  initial oil and filter change is done into a clean, light colored,  plastic shallow pan so I can see any metal particles that drain out with  it.   Straining the oil through a clean, white paint filter is  excellent practice.   You can then drag a magnet through the oil to  collect the particles that are ferrous for closer inspection of  potential problems.  Minor break-in particulate or "dust" is normal.   I  also cut open the oil filter and lay it out on clean white paper towel  to see what it has trapped and again look for any signs of trouble.   Yes, it's a lot of fiddling and checking but I find it infinitly  preferable to engine catastrophies (and a lot less expensive!).
     Once it is broken-in, you can optimize ignition timing and  jetting, preferably on a dyno.  During break-in keep the fuel/air  SLIGHTLY rich and the ignition timing essentially stock, NOT advanced.
     Even after break-in is done, always warm up the engine  thoroughly before riding/driving/flying per the above procedure to avoid  cold engine excessive wear or even possible "cold seizure" on liquid  cooled motors (most frequently occurs in marine or snowmobile  applications).
