Poll
Vote Now for May 2016 QOTM!!
iney0
5 (13.9%)
urns363R
7 (19.4%)
cs003
0 (0%)
ablack21
7 (19.4%)
em3500
3 (8.3%)
hesmith87250r
4 (11.1%)
roken1
10 (27.8%)
Total Members Voted: 36
Voting closed: May 01, 2016, 02:53:25 PM
Author Topic: Vote Now for May 2016 QOTM!!  (Read 15567 times)
« on: April 02, 2016, 08:51:22 PM »
May 2016 is an "anything goes" month.. post away!
Offline Piney0
« Reply #1 on: April 06, 2016, 11:27:27 PM »
I'll try this again.
Frame: 86 w/ pumashine gusset kit
A Arms: OEM
Swingarm: OEM
Steering Stem: OEM
Axle: Durablue
Carrier: Unknown brand
Bars: Pro taper CR Hi-bend
Grips: Scott
Front Shocks: Works tripple rate w/ remote ressies
Rear Shock: OEM
Rims F|R: ITP|Champion
Tires F|R: ITP Holeshots|GBC Sand Sharks
Body:
Plastic: OEM cut
Graphics|Seat Cover: STICKERS! | Ceet
Fuel Tank: OEM
Engine|Drive System:
Cylinder|Head: OEM
Bore & Stroke: 69 x 72 short rod
Displacement: 269.3
Carburetor: stock 34mm PJ
Reeds: Moto Tassanari
Air Filter|Box: Uni filter, Stock box
Pipe|Silencer: FMF
Gearing F|R:  13/38
Other:
Ridden hard, Ridden often
« Reply #2 on: April 07, 2016, 12:20:48 PM »
A Arms: JD +2 +1 Max Ground Clearance 89/spindles
Swingarm: 86 Lone Star 89 length
Steering Stem: Roll Design +2 +1
Axle: RPM Dominator 2 XC Width
Bars: Flexx bars
Grips: ODI
Front Shocks: Motowoz Triple Rate Comp/Reb Adjust
Rear Shock: Custom Axis
Rims F|R: DWT Bead Lock
Tires F|R: GBC XC Masters
Body:
Plastic: White Full Bore
Graphics|Seat Cover: STICKERS! |Psych MX Graphics/ Fourwerx Seat Cover
Fuel Tank: IMS 3.7 gallon
Hood: Fourwerx Scoop
Hand Guards: Power Madd
Nerf Bars: Rath Monster Peg
Bumper: PRM Summit
Grab bar: PRM Desert
Cylinder|Head: CPI Sphynx
Bore & Stroke: 78 x 76 short rod
Displacement: 363cc
Carburetor: 38mm Keihen Air Stryker
Reeds: VForce 3
Pipe|Silencer: BDT Wurks
Gearing F|R: 14/38
Other:
Magura Hydro Clutch
Bling Star Rotor/Sprocket Guard
CCP Steerign Stablizer
Silicone Blue Hoses
Oversized Radiator
LSR Billet Front Hubs
Upgrades installed soon:
IMS 4 gal dry break tank
ESR Quick change cover
EFM Auto Clutch
« Reply #3 on: April 08, 2016, 06:06:15 PM »
I will give this a try with my hybrid.
Frame: Modified 400ex (Slightly bent)
A Arms: OEM chromed
Swingarm: Custom round tube
Steering Stem: 400ex (bent)
Axle: LSR
Carrier: LSR
Bars: Moose 7/8" ATV bend
Grips: Scott
Front Shocks: HLS Dual Rate
Rear Shock: OEM/GT Thunder conversion
Rims F|R: ITP
Tires F|R: ITP Ohatsu
Body:
Plastic: Fullbore
Graphics|Seat Cover: STICKERS! | None
Fuel Tank: OEM 400ex
Cylinder|Head: OEM
Bore & Stroke: 66 x 76
Displacement: 260
Carburetor: 38 A/S
Reeds: Boyessen Rad Valve
Air Filter|Box: Uni filter, Custom aluminum
Pipe|Silencer: ESR 6; ESR silencer
Gearing F|R: 13/41
Other:
2001 cr250r Ignition
ASV levers
trx250r rear caliper
Custom Mod radiator
LSR Sub-frame.
Wet weight: 335 lbs.
Survived many crashes!
« Last Edit: April 08, 2016, 06:34:27 PM by jcs003 »
« Reply #4 on: April 20, 2016, 09:09:50 AM »
Frame: 88 gusseted
A Arms: +3+1 Lonestar DC-4 long travel
Swingarm: 88 oem powdercoated
Steering Stem: Lonestar +2 +1
Axle: Lonestar Dominator MX width
Carrier: Burgard Cycle double row
Bars: Fat bars
Grips: ODI
Front Shocks: Custom axis double rate long travel set up by Andy Maul
Rims F|R: ITP front/ Rock wheels beadlock rears
Tires F|R: Maxxis XM's
Body:
Plastic: Black Full Bore
Graphics|Seat Cover: Frankenstein MX race team graphics by SSI Decals
Fuel Tank: stock
Hood: N/A
Hand Guards: none
Bumper: DG
Grab bar: AC Racing
Cylinder|Head: World's first "Self Porting" engine
Bore & Stroke: 78 x 76 long rod (Before self porting took place)
Displacement: 363cc initially (After self porting - 396cc)
Carburetor: 40mm Billet Smart Carb
Reeds: ESR billet cage and reeds
Air Filter|Box: DT1, Stock box
Pipe|Silencer: ESR TRX 5B
Gearing F|R: 14/35
Other:
Magura Hydro Clutch
CCP Steering Stablizer
Silicone black Hoses
Oversized Radiator
LSR rear hubs
Special Customizations or attributes:
Motor can "self port" to obtain more breathing room as needed. Comes with a secret special "J" shaped crank rod that enables the self porting capability. Piston comes with a customized "breathing window" in the front to aid in exhaust and coolant flow. Note: Requires new cases after the first initial self porting cycle.
Offline dem3500
« Reply #5 on: April 21, 2016, 10:46:59 AM »
Frame: arens
A Arms: JD MGC
Swingarm: 88/89 OEM
Steering Stem: Walsh +1
Axle: lonestar
Carrier: lonestar
Locknut: lonestar
Hubs F|R: lonestar billet /lonestar taper lock
Bars: tag 1 1/8
Brake/Clutch Lever: ASV
Grips: spider
Foot Pegs: Rath
Bumper: Gradon
Grab Bar: AC wide
Front Shocks: elka
Rear Shock: elka
Brake Lines: stainless
Rotors F|R: OEM/OEM 450
Rims F|R: OEM EX
Tires F|R: GB XC master
Body: Maier
Plastic: maier
Graphics|Seat Cover: custom
Fuel Tank: Clarke 4 gal
Cylinder|Head: ESR
Bore & Stroke: 350 +4
Displacement: 363
Carburetor: 38 AS
Reeds: Rad
Air Filter|Box: aluminum /custom
Pipe|Silencer: ESR TRX 5b
Clutch|Plates: Tusk
Gearing F|R:
CDI|Killswitch: 01 CR250/ pro design
Cooling: CBR
Other: frame modified into pro peg to work with Rath 450 nerfs. Custom sealed airbox and full snorkel
« Last Edit: April 22, 2016, 07:30:10 AM by dem3500 »
« Reply #6 on: April 22, 2016, 12:39:51 AM »
  •    Chassis/suspension/controls
FRAME oem 88
A arms lonestar +2 +1
Steering stem lonestar +2
Lonestar carrier
Lonestar anti fade
Swing arm lonestar triple chrome
Axle dura blue +2
Hubs stock
Front shocks works triple rate
Rear shock pep 5/8 shaft
Tires hole shot
Duncan bumper
Pro taper bars
Body
Plastic maier white
Graphics seat cover one industry
Engine
Stock cylinder 68mm bore
210 psi 50/50 fuel mix
Displacment 265
Carb 38mm air striker
Reeds boysen
Cool head
ct pipe and fmf silencer
some updates since this pic . elka shocks , pt 2003 race pipe with fat boy silencer , new top end 68.5 piston , right side inner case
[/COLOR]
[/B]
[/LIST]
« Last Edit: April 26, 2016, 01:22:47 AM by thesmith87250r »
« Reply #7 on: April 22, 2016, 07:00:45 PM »
Frame: 86
A-Arms: OEM with uncontrolled auto adjusting caster(aka loose bushings)
Swingarm: 86 length Motoquad (a local shop that's no longer in business)
Stem: OEM chrome
Steering stabilizer: CCP
Axle: Durablue +2/+4
Carrier: OEM
Bars: Renthal/Bar pad from my old Hutch pro raider
Grips: Pro taper
Controls: OEM
Front shocks: Works
Rear shock: Works
Brakes F/R: OEM, +2 braided lines/OEM
Wheel hubs F/R: LSR ultralites/OEM
Axle hubs: Steel durablue sprocket hub/OEM rotor hub & locknut
Wheels F/R: Douglas red labels/Dico
Tires F/R: Kenda front max mohawks/Skat trak 8 paddle haulers
Body
Plastic: 86 OEM race cut & painted flat white
Graphics: Random stickers
Seat: 86 OEM
Hood & tank: 86 OEM
Grab bar: AC
Bumper: Old DG
Engine/drive train
Cylinder/head: Home ported OEM 86/Gasketed cool head with 22cc dome
Bottom end: Currently a spare stock 86ATC. The OEM 86TRX bottom developed trans problems
Bore/stroke: 67/72
Displacement: 250cc
Carb: 39PWK
Reeds: CR Rad valve
Air filter/box: K&N with outerware/homemade air box eliminator
Pipe/silencer: ESR trx5/fmf Q-silencer
Gearing: 13/39
Other: Purchased used in 1988. Had all the paint & chrome work done in 1990 & not much has changed since than besides the swinger, axle, shocks & pipe/silencer
« Reply #8 on: April 24, 2016, 02:53:46 PM »
May 2016 QOTM voting is now open!
« Reply #9 on: April 27, 2016, 06:22:37 PM »
Bump  to the top!
