Author Topic: another carb and more questions (41.5mm pwk air striker)  (Read 6989 times)
Offline Victork
« on: April 12, 2016, 10:20:35 PM »
I now have a 38mm as bored to 1.6300 inches (41.5mm)and am thinking about trying it on my bike over the 40.5mm pwk. I don't know much about modded as besides the fins are gone and it has 2 more vents obviously. 41.5mm vs non modded 40.5mm, thoughts?
Offline Aceman
« Reply #1 on: April 12, 2016, 11:47:31 PM »
What size is your engine?
Depending on the size, I've heard you can lose throttle response due to a weaker vacuum signal being pulled through a larger bore carb.  But, if you have a big enough motor to need it, you could gain some top end due to more air being able to flow through it.
Arens Axis XC 310R
Houser Axis Duner CT350PV
Offline Victork
« Reply #2 on: April 13, 2016, 12:07:41 AM »
350 pro x. I get the fact the extra 1mm will in theory shift the power higher but I'm wondering about the fact it's a air striker and has 4 vents and how the performance differs because of it
Offline Aceman
« Reply #3 on: April 13, 2016, 09:44:42 AM »
I just took delivery last night on an 86 stock framed R with a CT350PV cylinder.  I'm curious to hear what the other posters say as well.  I'll have to see what this one is running for a carb too.
Arens Axis XC 310R
Offline Victork
« Reply #4 on: April 13, 2016, 10:39:39 AM »
I wouldn't run anything smaller than 39 on a 350 that's for damn sure
Offline Victork
« Reply #5 on: April 13, 2016, 01:24:41 PM »
Can someone tell me is the 38mm as bored to a 41.5mm performs any different from a non as 41.5mm?
« Reply #6 on: April 13, 2016, 04:23:48 PM »
A 38 PWK bored to a 41.5 will perform the same as a 39 PWK bored to a 41.5.
Offline Victork
« Reply #7 on: April 13, 2016, 05:54:29 PM »
Thanks Jerry
Offline RIDE-RED 350r
« Reply #8 on: May 25, 2016, 06:35:51 PM »
Based solely on what I have seen said, the quad vent setup on the AS carb is mainly beneficial in applications where one is hitting jumps frequently, mainly MX. I am not an MXer so I cannot say if it is true or not based on my limited experience. I would defer to the wisdom of folks more experienced in this area for final judgement on that.
I recently replaced my PWK38AS with an ESR PWK bored to 41.2mm on my ESR 350. So far I am very pleased with it and I have not noticed any drawback about it in terms of only being a standard dual vent compared to the quad vent with the type of riding I do.. After all, how many years were dual vent carbs in use before the quad vent came out?
