Author Topic: More power?  (Read 17881 times)
Offline TRXDAN
More power?
« on: April 25, 2016, 12:37:31 PM »
have a question. but heres my set up first.its a 350 cylinder 78.5mm bore with a 5mil stroker crank trx11 porting and trx11 pipe. i'm looking for a tad bit more power. i am currently running a stock ignition, is that hurting me? also whats the most timing i can run on it?
More power?
« Reply #1 on: April 25, 2016, 12:56:13 PM »
Step #1 is the ignition. Looking for more anywhere else at this time will still be being held back from its potential by the ignition.
Offline TRXDAN
More power?
« Reply #2 on: April 25, 2016, 01:01:45 PM »
What are my options...cr250 ignition? Or?..id still like to have my light if possible
Offline Grande huevos
More power?
« Reply #3 on: April 25, 2016, 02:38:32 PM »
The cr ignition is a HUGE upgrade!!! Well worth the money. Some companies claim to rewind the stator for lights or you will have to go with a battery setup
Offline TRXDAN
More power?
« Reply #4 on: April 25, 2016, 06:28:43 PM »
guess ill be looking for a cr ignition. will i gain anything from advancing the time as well?
Offline turkey_drag
More power?
« Reply #5 on: April 25, 2016, 09:30:26 PM »
I got a cr ignition to try on mine as well TRXDAN, I also do some night duning so keeping the headlight was a necessity. Ill be going with the battery set up that Grande mentioned earlier. Led light bars dont draw as much juice as the halogen setups. With a good battery I should be able to get a few nights of riding on one charge. Ive heard that the rewound stators are not very reliable (dont know to the validity of that.) Due to the oilfield picking back up I havent had a whole lot of free time to install the cr and hook the light bar directly to the battery. Ill let you know how it goes, should be getting to it pretty quick.    Also, this is just my experience, my friend and I had more problems than good messing with the timing on a factory trx ignition. May work for others, but our setups didnt like it.
Offline kb250r
More power?
« Reply #6 on: April 25, 2016, 09:33:00 PM »
Do you have timing adjust plate, give it 4-6 degrees of timing,have it reported, custom cut dome .. Race gas with proper compression
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline TRXDAN
More power?
« Reply #7 on: April 25, 2016, 10:01:16 PM »
Quote from: turkey_drag;66922
thanks for the info turkey ill be looking forward to the updates
Quote from: kb250r;66923
no plate yet i will be ordering soon.  as far as custom dome yes. unsure of cc's but it cannot run on pump gas i built it for only race gas.
More power?
« Reply #8 on: April 26, 2016, 06:58:21 AM »
is this an older esr cylinder or a newer one... made within the past 2 years? reason i ask is the older style esr cylinders that eddie did for stroker cranks did not have the port timing adjusted correctly and can tend to be a bit down on power.
Offline TRXDAN
More power?
« Reply #9 on: April 26, 2016, 08:08:53 AM »
Quote from: JesseA420;66938
cylinder was bought in 2013. it runs very hard it runs side by side with 4 mil drag ported banshees. i have videos on youtube of it too....but to me the bike pulls hard on bottom end but seems to not rev out and pull in higher rpm. almost feels like a cr500.
More power?
« Reply #10 on: April 26, 2016, 08:31:35 AM »
well being a drag port and a drag pipe, it should be quite the opposite........  there may be more to the problem then just "needing more power"
Offline TRXDAN
More power?
« Reply #11 on: April 26, 2016, 08:36:06 AM »
Quote from: JesseA420;66940
when i got the cylinder bored for the first time the guy said it was out of squar really bad. really didn't understand what he meant.
Offline TRXDAN
More power?
« Reply #12 on: April 26, 2016, 08:39:17 AM »
i bought this motor from a guy it had low hours but he could not get it to run properly. when i got it, it would detonate a lot and blew quit a few head o rings before it finally had a light seizure and thats when i rebuilt it. but since then its ran great no more detonation/pinging or blowing orings.
More power?
« Reply #13 on: April 26, 2016, 10:21:42 AM »
Quote from: TRXDAN;66943
Is the TRX 11 pipe a center mount or out of frame silencer?
Are you using it for 300 ft drags only or other types of riding where you are at wide open throttle for more that 5 seconds at a time?
Offline TRXDAN
More power?
« Reply #14 on: April 26, 2016, 10:54:31 AM »
Quote from: Jerry Hall;66947
center mount With silencer. Its a hill shooter its about a 5 second run. Start from first and end up in high 4th at the end of the hill.
