Author Topic: 1988/1989 OEM TRX 250R frame  (Read 9311 times)
Offline Pontas
« Reply #15 on: May 29, 2016, 11:57:07 AM »
So, I have an 88 frame, or part of it at least, and all the rest from 86/87... That's good to hear...
« Reply #16 on: May 30, 2016, 02:39:58 AM »
That is a butchered 88/89 frame. Someone cut it up to accept an 87 swingarm. If you want to keep it an 89 frame, you will need to get an 88/89 swingarm or figure out a spacer. The 88/89 swingarm were solid all the way through on the pivot, didn't have the cut out like the arm you have there. If you go with an 86/87 frame you will need the bracket that fits in that notch. The bracket is the rear motor mount.
Also you will need foot pegs, or pro peg nerf bars. OEM pegs are not welded on like the frame you have there.
Offline Pontas
« Reply #17 on: May 30, 2016, 07:11:44 AM »
I'll probably go with an 88/89 frame and get an aftermarket swingarm. A-arms and the rest would be new anyways so, no worries there.
« Reply #18 on: May 31, 2016, 02:18:14 AM »
Honestly I like the stock 88/89 swingarms. They are aluminum. Nice and light
Offline Pontas
« Reply #19 on: July 02, 2016, 06:56:13 PM »
Only today I had the chance to check my engine's number. It's an 88, so I will need an 88 frame and swingarm.
Any help will be appreciated.
Offline jwraymond6
« Reply #20 on: July 02, 2016, 11:01:20 PM »
Your motor will fit in all 86-89 frames only the frames changed
Offline Pontas
« Reply #21 on: July 05, 2016, 10:44:05 AM »
Yeah, I know, but as the frame and the motor I have are from 88, I would like to build it as an 88/89 quad. ;)
