Author Topic: Need Cable for CR250r twist grip to 39mm PWK  (Read 4987 times)
Offline walz
« on: June 17, 2016, 01:26:27 PM »
First Question: is there a knowledgeable shop that I can call that will answer their phone and research the answer if needed?  BDT just said "no", carb parts warehouse has rang busy for 2 days, pj motorsports is gone till next week but still unsure, Sudco is hapless, the answers on facebook did not address different length for different size carbs or that PJ takes a longer cable than a larger PWK.  I am flying to another state to put a bike together in 24 hrs, if I had time I'd experiment.
Cable needed:  Connect a OEM CR250r twist throttle (happens to be 02-07 but shouldn't make a difference, it's 1/4 turn and made to open a 38mm) to a 39mm PWK.  95% sure a 2000 CR250r cable would work.  A part number would be preferred as the dealer and eBay sellers overlap years that I know do not work.
Appreciate your time.
« Reply #1 on: June 17, 2016, 06:23:43 PM »
I'd call motion pro they'd be able to help you, now if it was me I would never do business with bdt.
Offline StrokedAZ
« Reply #2 on: June 17, 2016, 08:07:43 PM »
I got a custom one made for me by terrycable.  It was for a magura twist off an old ktm to a 38 AS on my 86.  If they could pull that off I think they could do anything.  Motion pro wanted me to mail them my carb, throttle, and cable or they wouldn't guarantee it.
Sent from my Galaxy S5
86 TRX 250R
Offline walz
« Reply #3 on: June 17, 2016, 09:24:17 PM »
Cool thanks, I'll call motion pro direct.  I really don't feel like I am reinventing the wheel with this application but can't find a salesman to help if the answer is not right in front of his nose.  Sudco assumed a TRX400ex would be the same as my TRX250R with a PWK, I think he just felt happy for matching the "trx" part.
Carb parts has seriously had a busy signal from early till late then after hours I can leave a message.  They had no problems setting up my latest gen CR's with airstrikers and I'm pretty sure they know their stuff.
I did have high hopes for BDT since Carlos is knowledgable and active on the forums, in fact I thought he might be my new guy for motors.  His eBay clown and the male receptionist that answered BDT were far less than helpful.
Offline StrokedAZ
« Reply #4 on: June 17, 2016, 09:38:33 PM »
Quote from: walz;68276
That probably was Carlos lol
86 TRX 250R
« Reply #5 on: June 17, 2016, 09:56:24 PM »
For motor work you might look into Pete at Hybrid Engineering he's in Washougal.
Offline The_Steve_Man
« Reply #6 on: June 18, 2016, 08:07:21 AM »
You can go to partzilla and look at the cap. If it has the short adjuster it should work. Some have the 90 deg tube that will make the cable longer. The 38 and 39 use the sane cable. I am using the cable on my cr mikuni that I used on my pwk's.
Sent from my MotoG3 using Tapatalk
