Author Topic: WTB 88 trx 250 items  (Read 5472 times)
Offline mudbogger
« on: July 04, 2016, 09:27:58 PM »
Looking to purchase the following items for my project:
Kickstarter
Snap ring for excalibur axle, stock is fine according to excalibur to tighten brake hub.
Foot pegs, used, new, aftermarket, open to all
Handlebars for  LSR 1 1/8 ANTIVIBE , used new , open to all options
Grips for handlebars-vendors that sell them would be huge help
Lid for coolant overflow tank, will buy complete unit if needed.Used good here as well
2 upper tie rods for +2 Lone star a arms to fit 88 spindles.
Engine off/on lights on/off assembly for handlebars, used fine.
Rear brake foot lever, need hardware with it too please.
Mount for frame to keep coolant hose away from expansion chamber on right side of frame.
Air box rubber hose clamp, big clamp by air box
Intake clamp for carb to intake.
2 front rims and tires, preferred 190's alumn used or new good here as well.
« Last Edit: July 09, 2016, 03:49:31 PM by mudbogger »
« Reply #1 on: July 05, 2016, 12:09:45 AM »
What size front tires / rims ?
Offline mudbogger
« Reply #2 on: July 05, 2016, 01:42:32 PM »
Stock, anythong up to a 21 i am open too.
Offline FerrinMotorsports
« Reply #3 on: July 05, 2016, 05:31:26 PM »
I have most of what your looking for....I'm not going to have the mount for the radiator hose or the switch assembly...I'll PM you my number so you can text me....Jeff
« Reply #4 on: July 05, 2016, 10:49:49 PM »
Here's what I got:
« Reply #5 on: July 06, 2016, 07:48:01 AM »
The mount for an 86 87 front fenders won't work with 88 or later fenders I was having the problem solution was to get an 86 style radiator they have the bend in the radiator fitting.
« Reply #6 on: July 17, 2016, 01:19:54 AM »
Quote from: mudbogger;68549
Just saw these on ebay: http://www.ebay.com/itm/1988-Honda-TRX250R-Footpegs-/272309788974?hash=item3f66eda12e:g:2XcAAOSwdzVXikAS&vxp=mtr
Offline mudbogger
« Reply #7 on: July 17, 2016, 08:36:54 AM »
Quote from: broken1;68829
Git them thanks, and thanks for parts they worked well indeeed.
Still need some items
Rear brake lever with hardware
On/off switch headlight on/off assembly for handlebars
Rear tail light.
Offline mudbogger
« Reply #8 on: July 17, 2016, 08:37:57 AM »
Quote from: FerrinMotorsports;68558
Jeff any idea on your parts? Would rather purchase off the board them other sources. Thanks
Offline mudbogger
« Reply #9 on: July 17, 2016, 02:42:38 PM »
Quote from: thesmith87250r;68551
What size rims do i need to use with the lonestar +2 arms, the offset should be different then stick correct?
Offline 250rchris420
« Reply #10 on: August 22, 2016, 01:43:47 PM »
I have a complete headlight switch tc setup if interested. Also have a oem harness
Sent from my Nexus 6P using Tapatalk
Offline jto1
« Reply #11 on: August 22, 2016, 06:52:55 PM »
I have a new unopened set of nice grips I can get you some pics in a little bit.
