Author Topic: Paddle tires ?  (Read 21567 times)
Offline bcm
Paddle tires ?
« on: July 21, 2016, 05:16:21 PM »
I got 1988 trx250r with a esr 330 cylinder and a 4 mil stroker with a trx11 pipe and porting and I have been running 13-38 gearing but just changed to 14-36 to see if that helps. I was wondering what would be a better paddle tires set up, I have a sets of 21-12-8 8 paddle haulers single buff right now and saw a pair locally for sell that are 22-11-8 6 paddle haulers triple buff that a buddy said would be great for my set up and was wondering Which would be a better choice? I really think I should find a pair of 22-11-8 8 paddles haulers Thanks
« Last Edit: July 21, 2016, 08:28:18 PM by bcm »
Paddle tires ?
« Reply #1 on: July 21, 2016, 06:15:37 PM »
Quote from: bcm;68904
I got 1988 trx250r with a esr 330 cylinder and a 4 mil stroker with a trx11 pipe and porting. I was wondering what would be a better paddle tires set up, I two sets locally for sell one set of 21-10-8 8 paddle haulers single buff and also have a set of 22-10-8 6 paddle haulers triple buff. Which would be a better choice? Thanks
Are these going to be for drag?
Offline bcm
Paddle tires ?
« Reply #2 on: July 21, 2016, 06:17:18 PM »
Drag racing at the dunes , don't actually get to go to any sand drag strips now that our local track closed down
Paddle tires ?
« Reply #3 on: July 21, 2016, 08:22:41 PM »
The great paddle tire debate! Lol. I run  21-12-8 9 paddle haulers with my 310 4mil and for general dunning/tree shots (badass hill climbs with trees in the way) and occasional drag racing they are great. My gearing is 14-40 so it pulls pretty good. Seems like fewer paddles would mean less hook up. Good luck, Loren
Paddle tires ?
« Reply #4 on: July 21, 2016, 08:27:10 PM »
Down south they like less paddle then we do up here on my puma for a dune bike with a 140 lbs rider I run a 10 paddle ultra lite, if I was drag racing it I'd put a 12 maybe a 13.
Offline bcm
Paddle tires ?
« Reply #5 on: July 22, 2016, 05:57:03 PM »
I'm just asking I usually run 22-11-8 8 or 10 paddles on my banshee witch was just a stock stroke stock bore build but was very fast and I haven't had a 250r in awhile but everyone around here where I live runs 6 paddles on there 250r  310 builds and that just seams to be to little of paddles and they are very slow. I just trying to see what info I can get from everyone before I go and order up a new set because there is much up for sell lately for nice paddles
Offline bcm
Paddle tires ?
« Reply #6 on: July 22, 2016, 05:58:23 PM »
Skeans1 what gearing are you running on your 250r?
Paddle tires ?
« Reply #7 on: July 22, 2016, 06:12:15 PM »
The big question that too often gets left out of the paddle question...
Swingarm length??
The swing arm length goes hand in hand with what paddle will work to what degree and for what condition and desire.
Its like needing to know what bars are being used for a what stem height question and vise verse. A piece of the puzzle.
Offline bcm
Paddle tires ?
« Reply #8 on: July 22, 2016, 06:20:17 PM »
Plus 6 inch swingarm
Paddle tires ?
« Reply #9 on: July 22, 2016, 06:49:03 PM »
Is there anyone local to you that can let you try a 9 or 10 paddle?
Offline bcm
Paddle tires ?
« Reply #10 on: July 22, 2016, 07:21:16 PM »
No, but I just found a set of 10 paddles about two hours away that I'm going to pick up hopefully this weekend
Paddle tires ?
« Reply #11 on: July 22, 2016, 07:43:42 PM »
Quote from: bcm;68925
On my plus 5 14 38 but I could run a 36 in the rear without issues.
Offline bcm
Paddle tires ?
« Reply #12 on: July 22, 2016, 07:47:15 PM »
I have a 38 also is that a better option 14-38?
Paddle tires ?
« Reply #13 on: July 22, 2016, 10:21:21 PM »
Come to Pismo Aug 6th and I'll have 22" 9-10-12 paddles there your are more then free to try.
Paddle tires ?
« Reply #14 on: July 22, 2016, 10:26:01 PM »
I'm guessing a 22 8 paddle is where you want to be for a drag oriented tire.
