Author Topic: Ok folks, needing some info on the 450R swingarm set up  (Read 4637 times)
« on: July 26, 2016, 02:32:50 PM »
Need all the details for installing a TRX450R swingarm onto a TRX250R frame.
Thanks, Neil
« Reply #1 on: July 26, 2016, 04:52:43 PM »
Quote from: C-Leigh Racing;68993
Thanks, Neil
What year of frame and what year of swingarm Niel?
« Reply #2 on: July 26, 2016, 05:15:28 PM »
I think Kenny told me his was an 86 model R, but he had added the cross tube in the rear like the 88/89 frames for rear engine support.
Would probably use the shortest 450R swingarm, 04~05 which is probably 18" I believe.
« Reply #3 on: July 26, 2016, 05:17:35 PM »
Offline bmc1025
« Reply #4 on: July 27, 2016, 12:42:01 AM »
If you need any measurements from the 04-05 swingarm let me know. I have one with all bearings and bushings along with linkage. I plan on swapping it into my frame this fall/winter but the frame is a Lonestar no link not a stock frame.
« Reply #5 on: July 27, 2016, 04:49:25 AM »
have you considered a custom swingarm?  Tyson Racing does custom arms for $275.  Then you can get a specific length, it is made from chromoly tube.
John
Offline The_Steve_Man
« Reply #6 on: July 28, 2016, 05:29:49 PM »
The 04-05 is 18.5 ". -1 from a 85-87 atc/trx. The simplest way to do it is use the stock wishbone and an adjustable link. BKM aka Bryan Mulligan on facebook makes some delrin bushings for that swap.
It has worked great for me for a year and half so far.
Sent from my MotoG3 using Tapatalk
