Poll
Vote Now for November 2016 QOTM!!
wraymond6
10 (37%)
hesmith87250r
3 (11.1%)
errinMotorsports
7 (25.9%)
50rmanpuma
3 (11.1%)
cm
3 (11.1%)
to1
1 (3.7%)
Total Members Voted: 27
Voting closed: October 30, 2016, 11:19:04 PM
Author Topic: Vote Now for November 2016 QOTM!!  (Read 14665 times)
« on: October 03, 2016, 12:42:39 PM »
Anything goes this month!
Offline jwraymond6
« Reply #1 on: October 04, 2016, 08:07:04 PM »
Frame: 99 Lsr pro peg
A Arms: Lsr +3+1
Swingarm: stock 88 polished
Steering Stem: Lsr +2+1
Axle: Lsr
Carrier: Lsr
Locknut: stock
Hubs F|R: Lsr/Lsr
Bars: tusk fat bar
Brake/Clutch Lever: asv
Grips: odi
Foot Pegs: Ac pro peg nerf
Bumper: none
Grab Bar: unknown
Front Shocks: Elka stage 4
Rear Shock: stock
Brake Lines: streamline/stock
Rotors F|R: stock
Rims F|R: Unknown/itp
Tires F|R: unknown
Body:
Plastic: maier
Graphics|Seat Cover: ddr slap/ fourwerx
Fuel Tank:
Engine|Drive System:
Cylinder|Head: esr
Bore & Stroke: 72/66
Displacement: 310
Carburetor: 38 a/s
Reeds: vforce 3
Air Filter|Box: esr
Pipe|Silencer:esr trx6
Clutch|Plates: stock
Gearing F|R: 13/40
CDI|Killswitch: 2000 cr250
Cooling: stock
Other:
Offline jwraymond6
« Reply #2 on: October 08, 2016, 12:10:22 AM »
where them Rs at
« Reply #3 on: October 08, 2016, 01:48:07 AM »
   Chassis/suspension/controls
FRAME oem 88
A arms lonestar +2 +1
Steering stem lonestar +2
Lonestar carrier
Lonestar anti fade
Swing arm lonestar triple chrome
Axle dura blue +2
Hubs stock
Front shocks works triple rate
Rear shock pep 5/8 shaft
Tires hole shot
Duncan bumper
Pro taper bars
Body
Plastic maier white
Graphics seat cover one industry
Engine
Stock cylinder 68mm bore
210 psi 50/50 fuel mix
Displacment 265
Carb 38mm air striker
Reeds boysen
Cool head
ct pipe and fmf silencer
some updates since this pic . elka shocks , pt 2003 race pipe with fat boy silencer , new top end 68.5 piston , right side inner case
[/B][/COLOR]
Offline jwraymond6
« Reply #4 on: October 13, 2016, 12:31:18 PM »
Bump
Offline FerrinMotorsports
« Reply #5 on: October 14, 2016, 03:44:48 PM »
Frame: Custom JP with Walsh aluminum subframe.
A Arms: Laeger T-pin
Swingarm: No-Link
Steering Stem:Laeger T-pin with swivels
Axle:LSR +4
Carrier:LSR Billet
Locknut:Billet ASR
Hubs F|R:Billet RPM fronts...Billet LSR rear
Bars:Fasst Flexx Custom powdercoated
Brake/Clutch Lever:ASV levers with Magura hydraulic clutch
Grips:Custom billet/rubber
Foot Pegs:Pro peg
Bumper:RIS designs
Grab Bar:AC
Front Shocks:MOTOWOZ
Rear Shock:custom no link
Brake Lines:Stainless
Rotors F|R:Custom
Rims F|R:Beadlock 10x5fronts Beadlock 10x10 rears
Tires F|R:American Racer
Body:
Plastic:Maier
Graphics|Seat Cover:Custom ESR graphics QuadTech seat cover
Fuel Tank:oem with Chrome QuadTech cover
Cylinder|Head:ESR 330
Bore & Stroke:
Displacement:330
Carburetor:41.5 kehein
Reeds:ESR
Air Filter|Box:ESR air box delete
Pipe|Silencer:ESR TRX11 centermount
Clutch|Plates:oem with billet clutch basket
Gearing F|R:varies
CDI|Killswitch:oem ignition with RPM advancer and lightened flywheel Pro design kil switch
Cooling:Walsh radiator with custom Walsh Aluminum shrouds
« Last Edit: October 16, 2016, 02:04:35 AM by FerrinMotorsports »
Offline 250rmanpuma
86 r
« Reply #6 on: October 17, 2016, 07:48:24 PM »
 Frame: Stock
 A Arms: Full Flight +2 +1
 Swingarm: +2 Laegers
 Steering Stem: Stock
 Axle: Durablue +4
 Carrier: Lonestar
 Locknut: RAD
 Hubs F|R: 400ex front, 250r rear
 Bars:  Fatbar
 Brake/Clutch Lever: ASV
 Grips: ODI
 Foot Pegs:  Unhinged
Bumper:  trx450r Alba
 Grab Bar: Unhinged trx250r
 Front Shocks: Elka stage 3
 Rear Shock: Elka stage 3
 Brake Lines: American
 Rotors F|R:  400ex
 Rims F|R:    Alba Beadlocks
 Tires F|R:    Hooiser 150 MX
Body:
 Plastic:  Full Bore
 Graphics|Seat Cover:  Stock
 Fuel Tank:  Stock
 Cylinder|Head: Stock
 Bore & Stroke:  .20 over & Stock
 Displacement:   260cc
 Carburetor:  TM 42mm Mikuni
 Reeds:   V-Force Delta 3
 Air Filter|Box:  Open K & N
 Pipe|Silencer:  ESR ESR9 CM
 Clutch|Plates:  Hinson Plates & Fibers
 Gearing F|R:  14F 39R
 CDI|Killswitch: Stock
 Cooling: Stock
Other:
R6 Tailight
Offline bcm
« Reply #7 on: October 23, 2016, 11:32:54 AM »
Frame: stock
A Arms: stock
Swing arm: +6 fireball racing
Steering Stem: stock
Axle: stock
Carrier: stock
Locknut: stock
Hubs F|R: stock
Bars: tag
Brake/Clutch Lever: no brake,
Grips: tag
Foot Pegs: stock
Bumper: no bumper
Grab Bar: no grab bar
Front Shocks: stock
Rear Shock: stock
Brake Lines: rear only
Rotors F|R: rear only
Rims F|R: Douglas blue
Tires F|R: skat trak triple buff
Body:
Plastic: drag cut
Fuel Tank: stock
Cylinder|Head: esr 330
Bore & Stroke: 4 mil stoker
Displacement:
Carburetor: keihin from esr
Reeds: esr
Air Filter|Box: esr air box eliminator kit
Pipe|Silencer: esr trx-11 pipe and inframe silencer
Clutch|Plates: drag cut
Gearing F|R: 14-36
CDI|Kill-switch: kill switch
Cooling: stock
Other:
Offline jto1
« Reply #8 on: October 24, 2016, 02:43:30 PM »
Frame: stock 86
A Arms: stock 86
Swingarm: stock 86
Steering Stem: stock 86
Axle: rpm
Carrier: rpm
Locknut: rpm
Hubs F|R: stock 86
Bars: renthal
Brake/Clutch Lever: stock 86
Grips: scott
Foot Pegs: alba pro peg
Bumper: alba 450r
Grab Bar: armadillo drop
Front Shocks: 450r reworked to 250r specs
Rear Shock: stock 86 pep conversion
Brake Lines: ss
Rotors F|R: stock replacement
Rims F|R: itp and stock goldies
Tires F|R: itp xc 21x7x10/20x11x9
Body:
Plastic: maier race cut
Graphics|Seat Cover: custom made ddr slapp/ factor fx seat cover
Fuel Tank: stock 86
Cylinder|Head: stock 86 bhp ported /stock reworked for 110 by bhp
Bore & Stroke: 72mmx72mm
Displacement:295
Carburetor: kenhin 38mm pwk a/s
Reeds: vf2
Air Filter|Box: k&n outer wears and outer wears lid stock box & snorkel
Pipe|Silencer: esr trx6 & esr silencer
Clutch|Plates: Barnett basket and components/ 89 update/ cliegh mod
Gearing F|R: renthall 14/39
CDI|Killswitch: dynatek adjustable 2001 cr250r set on curve #2/ 2001 cr kill switch
Cooling: Api 3 core oversize
Other: 2001 cr250r ignition/ complete rebuild all body and engine bearings and bushings using oe components
Built to be a sleeper and look like a stock/lightly modded quad. Built from a frame, and a junk motor and cases, and peiced together from ebay and trx owners for life. A full resurrection from the dead and parted.
[ATTACH=CONFIG][ATTACH=CONFIG]12120[/ATTACH]12119[/ATTACH]
