Author Topic: Nikasil plating?  (Read 5164 times)
Offline seth
Nikasil plating?
« on: December 13, 2016, 01:03:40 AM »
I have the opportunity to pick up an older 310 cylinder.  I've been told it's at 73.5mm now and most likely will need to be bored.  I was wondering if going 74mm and having it nikasil plated would be an option I think this cylinder is an older sparks ported cylinder.  Is it possible to run 74mm on unbored cases and a stock transmission?
Sent from my Z981 using Tapatalk
Nikasil plating?
« Reply #1 on: December 13, 2016, 09:45:08 AM »
If the cylinder is currently 73.5mm, needing bored but would clean up by removing .25mm to .30mm it can be plated back to 73.5mm.  The plating is typically .10mm to .15mm thick on each wall.
Offline seth
Nikasil plating?
« Reply #2 on: December 13, 2016, 05:22:58 PM »
How much is it typically to plate a cylinder vs a new sleeve
Nikasil plating?
« Reply #3 on: December 13, 2016, 05:44:26 PM »
Contact Millennium. On phone right now other wise I would put the link up
Nikasil plating?
« Reply #4 on: December 13, 2016, 09:16:35 PM »
Around $225 for plating. If it truly is a Sparks cylinder I would definitely get the plating done and preserve that bad boy. Shouldn't need to bore the cases for a 310
Offline seth
Nikasil plating?
« Reply #5 on: December 14, 2016, 07:11:56 AM »
How can you tell if it's a sparks?
Nikasil plating?
« Reply #6 on: December 14, 2016, 08:23:06 PM »
Quote from: seth;71144
Engraving/markings on the cylinder. Post up some pics
