Author Topic: Sphinx vs. Puma  (Read 15192 times)
Offline 250rLaeger1
Sphinx vs. Puma
« on: August 01, 2013, 10:43:10 PM »
I was looking at CP industries web site and noticed that the 309 cc up to 363 cc sphinx has the exact same specs as the smaller puma of the same size... can anyone tell me the difference in the 2??
Offline derby
Sphinx vs. Puma
« Reply #1 on: August 01, 2013, 10:52:00 PM »
The port layout is going to be a little different between the 2.  The reed cage will be different (sphinx uses 250r and puma uses cr500).  Puma is going to be a little more costly to build.  I would bet that power between the 2 setups (same cc) would be very close in hp/tq.  I have yet to see any of the smaller puma cylinders run.
Offline matt250r21
Sphinx vs. Puma
« Reply #2 on: August 01, 2013, 11:04:47 PM »
Dose the Sphinx use a standard style TRX250R exhaust manifold?
Offline derby
Sphinx vs. Puma
« Reply #3 on: August 01, 2013, 11:11:13 PM »
It uses a cp manifold but it has the same od as a 250r manifold.  So you can use any 250r pipe with the sphinx.  The puma you can get either the large manifold or the oem od manifold.
Offline christph
Sphinx vs. Puma
« Reply #4 on: August 01, 2013, 11:20:08 PM »
I think the Puma is for drag motor applications (it allows for larger displacements) whereas the Sphynx is more of an all-around design.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
Offline atv fan 28
Sphinx vs. Puma
« Reply #5 on: August 01, 2013, 11:26:36 PM »
Puma's can be set up for a variety of applications. From MX to drag.
Offline motofool250r
Sphinx vs. Puma
« Reply #6 on: August 02, 2013, 01:42:26 AM »
sphynx cylinders come with more drag style port timing just like pumas. both can be setup to your needs from a real builder
pumas cost more because you have to do more internal work and get new reeds and then it moves the carb back about an inch also
« Last Edit: August 02, 2013, 08:19:15 PM by motofool250r »
Hybrid Stable
443cc LSR/Roll/Stellar Duner
363cc Backup Duner
In progress JP no-link Duner
Next bike now loading.....
Sphinx vs. Puma
« Reply #7 on: August 02, 2013, 09:50:54 AM »
Motofool, what do you mean you have to do more case work?  Yo have to bore the cases for both right? Is there something else you have to do for the Puma.  And as stated, either can be setup for what ever your needs are.
Sphinx vs. Puma
« Reply #8 on: August 02, 2013, 05:48:45 PM »
Quote from: Rupp250;7023
On the Puma's the cases have to be filled with epoxy before machining the cases. When done the builder usually makes a cut across the top to make sure no epoxy is above the surface.
Offline 250rLaeger1
Sphinx vs. Puma
« Reply #9 on: August 02, 2013, 05:55:58 PM »
Quote from: Pumashine;7053
is this on all the puma's, even the smaller bores like the 293cc?
would there be any benefit to use the smaller puma over a sphinx?
Sphinx vs. Puma
« Reply #10 on: August 02, 2013, 07:23:36 PM »
The pumas have a larger skirt O.D. Because they are designed to run 85mm and slightly bigger the spynx  does not have the extra meat in the skirts since its not designed for the larger pistons.
so the cases do not have be cut as large but if you were to start with a raw puma cylinder it could be cut with the thinner skirts but then you are limited on future bore sizes if you were to want more cc's
Offline GO OVRIT
Sphinx vs. Puma
« Reply #11 on: August 02, 2013, 07:48:46 PM »
So the cases don't need epoxy for the sphynx?  I thought I had seen that they did.
Sphinx vs. Puma
« Reply #12 on: August 02, 2013, 08:24:17 PM »
It would depend on the size of each setup your going to do, and each builder does it a bit different GO OVRIT, but the smaller Sphynx's should not require any epoxy,
i would not choose a small puma over a sphynx because the of reeds and pushing the carb back fitment issues and such. and air velocity of the larger reeds can make a difference.
Hybrid Stable
363cc Backup Duner
Sphinx vs. Puma
« Reply #13 on: August 02, 2013, 09:07:03 PM »
I have not done any sphynx cylinders yet so I can not comment much on them,but I agree with motofool on the smaller bore puma not being the prefered setup. I do think if you are building a 78 bore sphynx for drag racing a puma might be a better choice. But I have not done one to backup that statement just my thoughts.
Sphinx vs. Puma
« Reply #14 on: August 03, 2013, 01:50:21 PM »
if your comparing 2 different cylinders of the same bore size, i cant think of one situation where i would choose a smaller reed cage. i guess maybe trail riding a smaller one might be ok but otherwise im taking the larger one every time. hek my ktm 500 has larger cage than cr500 but still i think the ktm could be alittle bigger or atleast open the reeds slightly farther another 2mm or so.
