Author Topic: Does anyone still make this style seat latch?  (Read 7010 times)
Offline Allison#51
« on: August 02, 2013, 02:36:20 PM »
I'm looking for a new seat latch that has longer posts that use pins in them like this one. Does anyone make them new anymore? I know there used to be some like this on eBay but the guy hasn't been listing anything lately. The lonestar one isn't quite what I'm looking for but I guess I'll get that if I have too. Thanks, Jake
« Reply #1 on: August 03, 2013, 09:39:17 AM »
Quote from: Allison#51;7040
I have one of the LS new in the bag if you want me to measure the post for you.
« Last Edit: August 03, 2013, 09:52:41 AM by Pumashine »
Offline jamieg45
« Reply #2 on: August 04, 2013, 11:25:25 AM »
I would find a friend who has a machine shop and just have him make longer posts for that on, or find another set of the rear seat rubbers and do a little cutting on them to lower it down a little. That is what they use to do in the first place back in the day, I can remember seeing and having the cut ones myself.
01 Lsr 250r
00 Walsh 250r
« Reply #3 on: August 04, 2013, 01:35:07 PM »
^^ This. I have the RTC version (same thing),I cut my stock rubber's down,put on some washers the same diameter as the rubber and inner dia of post. Trim slowly to get the right height for a snug fit,works great!
« Reply #4 on: August 04, 2013, 03:54:08 PM »
What was the style that everyone was putting a group omf buy together for? Was that for the knob style or just looking to get the omf clip style?
« Reply #5 on: August 04, 2013, 04:21:40 PM »
Knob style,but what ever happened with that?
Offline Allison#51
« Reply #6 on: August 05, 2013, 12:59:20 AM »
Does RTC not have a site anymore? I couldn't get it to come up.
Offline Mosh22
« Reply #7 on: August 05, 2013, 10:39:15 AM »
Even though these say for a ATC 350X, they will fit the 86-87 TRX 250R if you re drill the holes for the pan mounting. They are made from stainless steel.
They will also fit the 88-89 TRX 250R if you cut the factory plastic pegs off the seat pan.
http://www.ebay.com/itm/Honda-ATC-350X-Custom-Quick-Release-Seat-Latch-Rear-Fender-Mount-Bracket-/330619763315?pt=Motors_ATV_Parts_Accessories&hash=item4cfa793a73&vxp=mtr
« Reply #8 on: August 05, 2013, 11:23:02 PM »
Yea but at $89 each? Not worth it to me
Offline lrd_250r
« Reply #9 on: August 05, 2013, 11:50:22 PM »
Text me at 661 873 5190 i think i have one
Offline Aceman
« Reply #10 on: August 06, 2013, 09:29:54 AM »
I just picked up a seat latch similar to that from Danhung.  The posts were too short also, I couldn't get the keepers through the holes.  What I did that was cheap and easy was to replace the screws with longer ones holding those dowels on.  Use a nut as a spacer between the flat plate and dowel to shim it down farther.  One 5/16" nut threaded on that longer screw worked perfect for mine.  When it's installed, the nut is inside the rubber bushing where you can't see it either.
Arens Axis XC 310R
Houser Axis Duner CT350PV
« Reply #11 on: August 06, 2013, 11:19:39 AM »
Offroadracer on .net has one for sale. He also has a screen name here, but I don't know what it is.
« Reply #12 on: August 06, 2013, 11:25:21 AM »
I think he is Offroadparts over here
Offline Fear250r
« Reply #13 on: August 24, 2013, 08:26:33 AM »
Quote from: Hawaiiysr;7423
Me neither.  I bought a latch like this, although it was a few years back, used on ebay for like 12 bucks.
In house hybrid ball buster
Offline Allison#51
« Reply #14 on: August 24, 2013, 11:50:54 PM »
I ended up getting the seat latch that I posted a picture of. When I started the thread it had been in an eBay listing and the auction ended but the seller still ended up having it so I bought it off him. It was a little more then I wanted to pay but man this thing fits nice with the 88 rear seat grommets. I'm actually going to have some shorter ones made up at work though so I can use the thinner seat grommets and lower the seat height.
