Author Topic: Toy hauler air compressor  (Read 12450 times)
« on: February 21, 2017, 04:49:08 PM »
I do a lot of sand camping and I have to deflate my truck and toy hauler tires to get out in the sand. I bring an air compressor that does a decent job of filling all my tires. It is a rigid 5 gallon, 4 cfm, 145psi from home depot. I'm worried about it giving up the ghost because of its age and amount of abuse it's handled. I'm looking for a potential replacement. This particular compressor is no longer available. I want an oil lubricated 4+ cfm@90psi 10-20 gallon portable compressor. Obviously the higher the cfm the better. I appreciate your help and ideas. Thanks, Loren
« Reply #1 on: February 21, 2017, 07:41:17 PM »
Quote from: The norm;71854
Loren give Portland compressor or C&H a call in town they'll set you up right. Then look at the JJ&A fill manifold for a few ideas.
« Reply #2 on: February 21, 2017, 08:21:56 PM »
Quote from: Skeans1;71855
I'm not really looking for a salesman. I know that I can go down to C&H or any other like store to get their advice. I was asking to get other sand camping enthusiasts thoughts and opinions. Thanks though Jared.
Offline jwraymond6
« Reply #3 on: February 21, 2017, 08:38:07 PM »
I've thought  about doing on board air on mine
« Reply #4 on: February 22, 2017, 04:58:29 PM »
Would it be feasable to add an on board compressor to your pickup using an old ac compressor & auxiliary tank?
« Reply #5 on: February 22, 2017, 05:50:06 PM »
Quote from: broken1;71868
I would actually prefer onboard air, but I'm not sure what kind of performance I would get out of it
« Reply #6 on: February 22, 2017, 07:06:22 PM »
I have no personal experience with it but a guy we used to wheel with had onboard air on his fj40 & it seemed to work pretty good. It didn't fill the tires in seconds or anything like that but he always had air when he needed it. Just did a search & found this: http://www.duramaxdiesels.com/forum/showthread.php?t=20842
Offline jwraymond6
« Reply #8 on: February 22, 2017, 08:51:36 PM »
Quote from: jwraymond6;71877
There's these systems for on board air
http://www.4wheelparts.com/Air-Compressors-Air-Tanks-and-Air-Accessories/VIAIR-Constant-Duty-Onboard-Air-System-10007.aspx?t_c=89&t_s=566&t_pt=100435&t_pn=V/A10007
Nice thing about this system is the truck don't need to be running like it would with a converted ac compressor.
« Reply #9 on: February 22, 2017, 10:43:24 PM »
I looked at this the other day. It's only .97 cfm @90psi. I'm not a scientist so I don't know what cfm is ideal for filling tires quickly. Keep in mind that I have to fill 10 tires lol
« Reply #10 on: February 23, 2017, 12:24:51 AM »
i used this on the duck boats to worked great.  read the 1st review at the bottom of the page.  https://www.walmart.com/ip/35187872
« Reply #11 on: February 23, 2017, 10:37:41 AM »
Loren stop by in have a small compressor that was strong enough to run an impact you can try been a few years since I tried it.
« Reply #12 on: February 23, 2017, 10:54:22 AM »
Current compressor
« Reply #13 on: February 23, 2017, 01:50:35 PM »
This is what I'm using now. It will fill my tires from 15 psi to 75-80 psi @4 minutes per tire. Ten tires takes 40 minutes. If I can't do any better without bringing my 60 gallon Quincy then oh well. Thanks for the input guys
« Reply #14 on: February 23, 2017, 11:03:54 PM »
Quote from: The norm;71914
Only thing that might is the ones off the dmax engine name escapes me off hand Loren.
