Author Topic: WTB fuked up bent stock axle  (Read 3893 times)
« on: September 22, 2017, 10:01:56 PM »
I really only need the from the sprocket to the disc. I have a disc and a sprocket so those parts are not needed either. I have a idea in mind and I'd like to use this for mock up. So if you have a fuked up axle and don't mind chopping off the ends please lmk. Cheaper the better
« Last Edit: September 22, 2017, 10:04:25 PM by Hawaiiysr »
Re: WTB fuked up bent stock axle
« Reply #1 on: September 22, 2017, 11:25:55 PM »
I'll try to locate my old axle. If I can I'll send it out promptly.
« Reply #2 on: September 23, 2017, 02:38:06 AM »
Is it junk? I want a junk one. Cause if it's usable I'm going to end up using it. I wouldn't want to chop up a good part
« Reply #3 on: September 24, 2017, 01:50:47 PM »
It's my old chrome oem axle & it got bent where it tapers down next to the right side wheel hub. I might have thrown it away though. If I did I have another axle that has bad wheel hub splines on one side & I know where that one is. If your cutting the middle out can I do that before shipping so it will fit in a flat rate box?
« Reply #4 on: September 24, 2017, 03:36:50 PM »
yea! that would be perfect!
