Author Topic: How to ship an axle for $19  (Read 3889 times)
« on: September 28, 2017, 04:45:35 AM »
I found a great way to get cheap shipping on an axle. This one is going to Hawaii & since shipping there is so expensive I ended up just cutting the axle into 3 piece's & was able to get it into a large flat rate box with the sprocket hub still on. Since the axle is hollow it will be easy to put a piece of 3/4" rebar in there for reinforcement & weld it back together. Have fun with the fab work Josh :)
http://thumbs.imagebam.com/de/8d/7d/2bb903611713213.jpg?nc
http://thumbs.imagebam.com/ac/8e/31/31c897611711763.jpg?nc
http://thumbs.imagebam.com/a1/64/62/2c4cfa611714223.jpg?nc
http://thumbs.imagebam.com/3d/04/9f/cc4f36611715343.jpg?nc
« Last Edit: September 28, 2017, 05:01:04 AM by broken1 »
Re: How to ship an axle for $19
« Reply #1 on: September 28, 2017, 01:11:16 PM »
ill just chuck it up in my drill press and get it true after i slug and weld it  :) thanks Kevin!
« Reply #2 on: September 28, 2017, 03:15:45 PM »
Maybe use some bolts on the slugs so it can always be taken back apart for future shipping LOL
« Reply #3 on: September 28, 2017, 07:49:17 PM »
good idea!
« Reply #4 on: September 28, 2017, 10:37:34 PM »
Way to think outside the box Gene.
« Reply #5 on: September 29, 2017, 08:59:20 AM »
is this for real? lol
« Reply #6 on: September 29, 2017, 06:42:36 PM »
You could cut another axle apart but at different lengths. That way you would have options as far as axle width goes. So like a quick change axle for trails or track lol!
« Reply #7 on: September 29, 2017, 09:48:45 PM »
quick change axle! dam keep the ideas coming! lets get on this boat. we should stop talking about this. keep it to pm's. CoC gonna cop the idea and find the original molds for the axles in japan. SHHHhhhh! keep it on the DL. like 3rd building area 51 pro flow dyno sheet down low.
« Reply #8 on: September 29, 2017, 09:53:38 PM »
If you used a long enough slug you could make different width spacers so you wouldn't have to cut up a second axle.
« Reply #9 on: September 30, 2017, 12:49:01 AM »
You know to make it so anybody could make it. Maybe use sleeve retainer on the slugs. So with some heat it can be taken back apart.
