Author Topic: LT500R air boot  (Read 3852 times)
Offline matt250r21
LT500R air boot
« on: April 03, 2018, 05:04:41 PM »
Anyone got a good condition quadzilla air boot they want to part with? Looking for the boot that goes from the carb to the air box. Thanks
Re: LT500R air boot
« Reply #1 on: April 05, 2018, 09:19:48 PM »
These are still available new from Suzuki. Number 12 on the list... There a little expensive but at least you know you can still get one if a used one doesn't pop up.
https://www.motosport.com/atv/oem-parts/suzuki/1989/lt500r-quadracer/air-cleaner
« Last Edit: April 05, 2018, 09:25:05 PM by broken1 »
Offline matt250r21
Re: LT500R air boot
« Reply #2 on: April 07, 2018, 09:53:28 AM »
Thanks for the info, I found a better solution then the LT500 boot
Re: LT500R air boot
« Reply #3 on: April 07, 2018, 01:00:23 PM »
What did you find that was better solution?
Offline matt250r21
Re: LT500R air boot
« Reply #4 on: April 07, 2018, 01:33:35 PM »
I switched from a screw cap Keihin 38 PWK A/S to the KTM Keihin 38 PWK A/S short body carb, this left me 20mm overall too short from the carb bell to the air boot. I did not want to run any reed spacers because the whole point is to get the carb closer in and I have only scene 1/2 inch (13mm) or 1/4 inch reed spacers, so I would have 2 reed spacers stacked, yuck . Thought about moving the air box and 86 air boot closer but then I would possible crush it if I bottomed out the suspension. Thought about 4 inch PVC spacer junk, then thought maybe I could cut down and re shape an LT500 air boot. All of these solutions might work but seemed half azzed. Then I remembered ESR use to sell a Mikuni TMX carb with a pressed on adapter ring. After a little searching I found a company called Mikunioz that sells a 62mm OD spigot adapter with 60mm ID thats 20mm long. This should work perfectly I hope.
