Author Topic: Stiff clutch  (Read 4571 times)
Stiff clutch
« on: August 03, 2018, 10:46:44 PM »
I just replaced the clutch springs and cable and the clutch pull is extremely stiff. I had the clutch out and didn't see anything wrong. I need to get this figured out asap. Any ideas?
Re: Stiff clutch
« Reply #1 on: August 03, 2018, 11:43:30 PM »
What springs did you use
Re: Stiff clutch
« Reply #2 on: August 04, 2018, 11:09:54 AM »
I ordered what I thought were oem 88-89 springs. The seller used a trick we no too well.... Oem honda packages cut open with unknown brand parts in the bag. I have tried several different springs I had with the same result every time. I guess I will pull the clutch out and see if the rod is bent. I did that when I had the bottom end apart and it looked just fine.
Offline 2Nubs
Re: Stiff clutch
« Reply #3 on: August 04, 2018, 12:12:53 PM »
Man that is dirty right there.
I hope you get it figured out quick.
‘86 330
Re: Stiff clutch
« Reply #4 on: August 04, 2018, 01:52:43 PM »
I used my phone a friend backup plan.  Thanks broken1......
I just pulled the clutch out and reassemble it. Nothing looks out of spec or in poor condition. It has to be the springs
Re: Stiff clutch
« Reply #5 on: August 06, 2018, 06:58:23 AM »
while you have it apart you might want to do the Neil clutch mod.
Re: Stiff clutch
« Reply #6 on: August 06, 2018, 08:25:28 AM »
The 89 update is on the list also
