Author Topic: Exhaust Stinger Temps  (Read 4731 times)
« on: August 06, 2018, 10:22:44 PM »
Guys - need replacement hose for the pipe to stinger joint.  The high temp eBay stuff is rated to 500*F.  I know EGT’s will obviously be hotter but not sure how hot that joint actually gets.  So is a 500*F rating sufficient or do
I need more?
Re: Exhaust Stinger Temps
« Reply #1 on: August 07, 2018, 12:12:00 AM »
I have been using copper rtv for the joint lately. It's rated at 700 if I remember correctly. I have also used red rtv which is rated at 500. Neither has failed from heat so I would say a 500 degree rated hose should be ok.
« Reply #2 on: August 07, 2018, 12:20:21 AM »
Thanks Loren
Offline Piney0
« Reply #3 on: August 07, 2018, 07:48:45 PM »
I use the Ebay silicone hoses at that joint.  Haven't had an issue, and it's been on there for roughly 4 years.    I don't think the EGT's are that high that far back on the pipe on our 2 strokes.
« Reply #4 on: August 07, 2018, 11:01:28 PM »
Thanks. I just bought one to test.  If that works then I’ll see about building up some clamps.
« Reply #5 on: August 07, 2018, 11:01:51 PM »
Thanks Loren.
