Author Topic: 01/00 Cr cdi try?  (Read 10229 times)
Offline Sand_Blaster
01/00 Cr cdi try?
« on: May 08, 2019, 05:16:01 PM »
I know this is a long shot, but would anyone have a 01 or 00 cr cdi I could try? I think mine is crapping out, I don't want to commit to $200-$300 if it's not the cause. I would gladly pay for shipping both ways. If not, then this set up will go up for sale. Thx.
87 Trx250r & 99 Banshee
Re: 01/00 Cr cdi try?
« Reply #1 on: May 09, 2019, 05:55:38 PM »
You might have better luck shipping your CDI to someone to test it.
« Reply #2 on: May 09, 2019, 08:41:02 PM »
Thx gene more I work on my R I am saying F it and it's going to Arlan in a few weeks for a HPI ignition, dyno and tune. I'll see what's this cr ignition is worth or ill save for my 88.
« Reply #3 on: May 09, 2019, 10:54:43 PM »
I still think it is a ground issue. Since it doesn't do it all the time
« Reply #4 on: May 09, 2019, 10:55:52 PM »
You will be better off in the long run to fix it your self. It's a learning experience
« Reply #5 on: May 09, 2019, 11:44:27 PM »
It ran fantastic on the first R ride and up till that Sunday on very last ride. Then after climbing the drag hill, it all of a sudden started running like garbage cutting out real bad when I gave it gas. I had to be towed back. Now it's doing the same thing on my brand new motor when I give it some thumb it acts like a throttle limiter. Hard to explain properly. It idles great, but blip the throttle it cuts out. Not a jet issue, electrical for sure. Ran a ground from coil and no changes. Bought a new coil, but the company sent a cr500 lol.
« Last Edit: May 09, 2019, 11:48:31 PM by Sand_Blaster »
« Reply #6 on: May 09, 2019, 11:46:50 PM »
If it's say a cdi issue or stator I'd hate to buy a replacement for big money, but a hpi is $320 something complete.
« Reply #7 on: May 10, 2019, 03:47:20 AM »
The extra ground you ran from the coil. Did you go to the motor with it
« Reply #8 on: May 10, 2019, 11:43:24 AM »
Have you done a resistance tests on the stator?
« Reply #9 on: May 10, 2019, 12:23:58 PM »
bummer i hate chasing electrical issues. id lend you my cdi but im moving soon and i need to be able to start my R.
next motor i build im going with a hpi. i dont run lights so it just makes sense for me.
« Reply #10 on: May 10, 2019, 04:07:00 PM »
I haven't yet maybe I will. I'll run the ground to the cylinder here soon when I get time to tinker with it.
Offline Piney0
« Reply #11 on: May 11, 2019, 02:42:32 PM »
I have a 2000 CDI I can send you to try.  let me find it first.
« Reply #12 on: May 12, 2019, 12:41:57 PM »
Thatd be fantastic if you'd do that.
Offline Piney0
« Reply #13 on: May 12, 2019, 04:35:53 PM »
I found the 2000 CDI that I have.  I'll send you a PM.
« Reply #14 on: May 13, 2019, 09:15:25 PM »
Text sent!
