Author Topic: Wiring harness - Request for 3 prototype testers  (Read 14877 times)
Re: Wiring harness - Request for 3 prototype testers
« Reply #15 on: May 08, 2021, 08:12:23 AM »
I converted an 88 stator today to 89. While I was there I found that the ignition wire wasn't crimpted properly at fhe factory surprisingly and a few wire strands had broken.
If you like I can look at your stator and refurbish the connectors if needed. A quality harness with new connectors is only one half obviously. The stator side should be in good shape as well ideally.
@All250R are you still redoing the stators?
Thanks
