Workshop
Suspension and Chassis
Brake Piston Cover Came Off Piston
Topic: Brake Piston Cover Came Off Piston (Read 2596 times)
havinnoj
Administrator
Total likes: 185
May 29, 2020, 07:35:50 PM »
Rebuilding 400EX calipers and upon inserting the piston, the "cover" separated from the piston body. A new OEM piston is $55ish, would like to spare that if possible. Are there options for reattaching or do I bite the bullet?
broken1
Total likes: 156
Re: Brake Piston Cover Came Off Piston
May 29, 2020, 09:05:44 PM »
Are they the phenolic piston with the crimped on stainless cap?
2ndmoto
Total likes: 51
May 29, 2020, 09:59:56 PM »
Seems like loctite Henkel should have a product for high heat. They have all sorts of bearing retaining1. It's risky. You don't want it to fall off. 2. The product might be as costly as the new piston 3. How well does it hold up to heat.
You will what a product that has high sheer strength
Personally I would get a replacement from k&l, braking...etc
Workshop
