Author Topic: LRD Attitude build  (Read 28108 times)
Offline evaneyeball
Re: LRD Attitude build
« Reply #15 on: August 01, 2020, 09:26:02 PM »
This bike is definitely going to have a attitude
LED built 86 trx 350 CEO
81 ATC250r
Offline ajbuilder250r
« Reply #16 on: August 04, 2020, 10:43:43 PM »
How many pounds are saved vs a stock frame?
Offline desertR
« Reply #17 on: August 04, 2020, 11:06:39 PM »
I don't think weight saving is considered on an aftermarket frame, Tubing diameter and wall thickness, are optimized for strength first, with any weight being of a secondary concern.
desertR
« Reply #18 on: August 05, 2020, 04:02:12 PM »
Why build it out of aluminum if not trying to save weight?  Just wondering.
« Reply #19 on: August 05, 2020, 04:19:26 PM »
I would like to think that aluminum is used for weight savings and rigidity. Aluminum doesn't flex like steel or chromoly. With aluminum you can use a larger diameter tube (which adds rigidity) with a relatively thin wall thickness. So you should be able to shed some weight and produce a more rigid frame.  I could be way off the mark, but it makes sense to me.
Those LRD aluminum frames look beefy! I love the look for sure.
Loren
« Reply #20 on: August 05, 2020, 04:23:52 PM »
The LRD frame is 32 pounds.  A stock frame is 38 pounds.
Offline Action69
« Reply #21 on: August 06, 2020, 12:19:01 AM »
I didn’t weigh it but just by picking it up it felt quite lighter than a stock frame..
Offline desertR
« Reply #22 on: August 06, 2020, 01:59:17 AM »
6 lbs isn't much, pull the rear caliper brake mechanical and cable and assoc parts and that's 2lbs. Stock pipe and muffler is an easy 5/6 pounds.
I think it's more about better rear shock workings and perhaps better geometry. I still believe that weight is secondary to strength. If all it was is weight we would have seen a lot more aluminum, titanium, and/or beryllium frames, regardless of toxicity. Aluminum is more rigid then steel but if Honda really wanted to, they could have made their own "race" frame, in limited production runs. Honda builds a lot of aluminum frames for other units, they have the technology and processes. It's hard to say how Honda justifies production changes or numbers, if they had continued production past '89' things might have been different, but we'll never know. I don't think Honda predicted the continued popularity of the 250r some 30 years later.
desertR
Offline Action69
« Reply #23 on: August 06, 2020, 09:56:45 AM »
I personally didn’t buy it for weight savings,I just think it’s a bad ass frame..
« Reply #24 on: August 06, 2020, 10:49:08 AM »
Excellent reason in my humble opinion!
« Reply #25 on: August 06, 2020, 02:31:47 PM »
Honda had the design for a new engine. the patent drawing are floating around
Offline Action69
« Reply #26 on: August 09, 2020, 12:44:38 PM »
I just bought this bad boy,supposedly has two days usage.looks super clean..
« Reply #27 on: August 09, 2020, 12:55:29 PM »
I remember those silencers! My buddy had one for a 4stroke on his LRD built 700cc 2001 raptor. It was loud!
Looks good Steven. I can't wait to see the finished bike!
« Reply #28 on: August 09, 2020, 01:06:18 PM »
I have that same exhaust but not quite as nice. The silencer was red but the agonizing was faded & ugly so I glass beaded it. After blasting you can still see the etched script on the silencer.
Offline Action69
« Reply #29 on: August 09, 2020, 01:23:50 PM »
I thought it would be a nice addition to the build ,Loren hopefully you see it in person at next years meet.id really like to make it and send one of my 250rs..if anyone is on the east coast and would be willing to share transportation to next years meet I’d be interested..
