Author Topic: whats next after break-in jetting?  (Read 3793 times)
Offline hondaman77
« on: August 12, 2013, 10:56:43 PM »
Guys,
i have a 38mm A/S on a ported OEM cylinder. i just finished my break-in period. bike runs pretty good but i can tell its rich due to the sponge on the silencer (Allen from CT set it up and said it would be a little fat). what are my next steps/sizes to test this weekend?
currently: DGJ (third clip), 50 Main, 175 Pilot. riding at sea level.
Thanks.
Offline atv fan 28
« Reply #1 on: August 12, 2013, 11:05:46 PM »
i would do some plug chops... And go from there
Offline hondaman77
« Reply #2 on: August 12, 2013, 11:13:42 PM »
wasn't sure if i should make an adjustment/change something then do a plug chop since i know it was setup rich???
« Reply #3 on: August 13, 2013, 12:10:33 AM »
I would only trust the plug to tell me what jetting I needed on a fresh motor
« Reply #4 on: August 13, 2013, 07:31:16 AM »
do you have a temp gauge?  a temp gauge will help with tuning too.
« Reply #5 on: August 13, 2013, 08:29:50 AM »
Quote from: hondaman77;8317
Rich won't hurt your cylinder. Running lean will seize the piston. If it is obviously too rich with the plug check then you can go down a jet size on the main. Better safe than sorry. Alot depends on the pipe you are using. I fried my piston with a 175 main jet using a PT race pipe on a OEM ported cylinder.
Offline GO OVRIT
« Reply #6 on: August 13, 2013, 09:38:40 AM »
How does it feel?  Does ot start easy and idle good? Any flat spots or sputtering?   Your plug tells a lot, but the feel and sound is important too.  If you do start changing anything, do one thing at a time.
