Workshop
Suspension and Chassis
$200 full front brake rebuild
Topic: $200 full front brake rebuild (Read 4385 times)
broken1
Total likes: 156
January 21, 2022, 06:54:29 PM »
Just finished the rear brakes & getting started on the front's. I figured they'd cost more but luckily just like with the rear caliper the piston's & floater pin's were all in good shape which keeps the cost down considerably. Just like the rear I got Shindy kits for both calipers & mc, oem bleeders, pin plugs & a new mc diaphragm along with new EBC pads & Galfer +2" 3-line kit it cost just over $200 for everything including a can of VHT cast aluminum caliper paint:
Both calipers needed new piston inserts so I used the same micarta I used for the rear inserts & made 4 more:
To get the piston's out I like the grease gun method & if you do it when there's still residual brake fluid in the calipers it makes removing the grease from the piston bores much easier. I used a metal rod to get the grease out of the caliper & the last picture shows how clean the grease comes out if your careful:
Last Edit: January 21, 2022, 07:04:05 PM by broken1
Workshop
