Author Topic: SmartCarb SC2 38mm  (Read 9868 times)
Offline gentner8
SmartCarb SC2 38mm
« on: July 14, 2022, 08:37:53 AM »
After being on the fence about what carb I wanted to run, the SC2 caught my attention.  After reading many reviews, with some positive, and some negative, I decided to give it a shot.  I gave them the details on my setup, as well as possible future planned mods.  8 weeks later, it finally arrived, and got installed.  The bike fired up on the first kick, and had a nice fat blubbery idle.  Even with it running pretty rich, it has great throttle response.  It's still really early, and I need to do a little tweaking to lean it a bit.  But I will say, out of the box, I'm seriously impressed on how close the "jetting" is.  On the east coast, my temps range from 0-100, and low humidity to 100%.  Im hoping it lives up to its name.  I used a dremel to remove a bit of material from the factory air boot, right at the top where the venturi is, to be sure it was exposed as required.  It was a tight fit with the boot, but a little heat, and some choice words got it done.  Im not saying this is the carb for you, but it seems to be working well for me so far.  Hopefully I can update this post in a few weeks when I get some real time to dial it in.
Re: SmartCarb SC2 38mm
« Reply #1 on: July 15, 2022, 04:48:34 PM »
I am glad the smart carb worked for you. We were running 400+ cc motors. Jetting to lean and burned a few bores. X tra crispy throttle response. But seemed to die for no reason. Have not been able to play with them since I lost use of my right arm. Thanks for the update, Pumashine
Offline gentner8
« Reply #2 on: July 16, 2022, 12:34:49 PM »
Sorry to hear about your hand.  As for the SC, I'm hoping my opinion doesn't change as I attempt to get it fully dialed in, but I'm also not running any wild motor combo as of yet.  I'll be sure to report back if and when I smoke a piston.  I will get some real ride time in about 2 weeks, and we will see what happens.
« Reply #3 on: August 04, 2022, 01:38:46 AM »
I've had great success with the SC. It is imperative that you don't use the stock intake boot. The orifice at the top of bell needs a clear shot at incoming air. The  settings it came with were spot on. 40mm on a LED 363.
