Author Topic: OEM Black Air Dam w/ Maier Front Fenders  (Read 12580 times)
Offline bushwesl
« on: September 18, 2022, 11:37:26 AM »
I’ve never owned Maier fenders before. Is the front lower black air dam used/able to be used with Maier front fenders?
Re: OEM Black Air Dam w/ Maier Front Fenders
« Reply #1 on: September 18, 2022, 12:19:24 PM »
I don't have Maier fenders but since they don't have the molded in spots for any of the mounts my guess would be that there's no mounts for the air dam either but something could probably be integrated into them.
Offline bushwesl
« Reply #2 on: December 18, 2022, 05:21:00 PM »
I picked up a set of new Maier fenders with the intention of figuring out how to make the front air dam work. I’ve included the instructions for reference.
Offline bushwesl
« Reply #3 on: December 18, 2022, 05:22:23 PM »
There are two brackets that you add for the 86/87 air dam; the 88/89 isn't an option. The two brackets secure the air dam in the rear only and there isn't anything that actually connects the air dam to the front plastics. I really had to hack up my air dam to get all of the supplied Maier brackets to sit into position and get it all to work together. It wasn't a big deal for me since I already hacked mine up to fit with the shock tower gusset, but it may be for others. Here's the hacked up air dam and with it sitting into place.
Offline bushwesl
« Reply #4 on: December 18, 2022, 05:24:14 PM »
I was finally able to get it to sit pretty well. I still might tweak it a little bit and also add a couple of zip ties to hold the air dam to the front fenders someway, which I hope will take up the rest of the gaps that can be seen. From a distance, it doesn't look too bad.
« Reply #5 on: December 18, 2022, 09:37:35 PM »
Turned out nice
« Reply #6 on: December 19, 2022, 11:03:23 AM »
Thank you for the write up.
Offline atvmxr
« Reply #7 on: December 29, 2022, 11:52:04 PM »
Interesting.  Just realized my 88 oem are missing the whatever version is offered after 86.   Hood only
