Author Topic: left case half - broken  (Read 3481 times)
Offline All250R
« on: September 04, 2023, 09:07:14 PM »
I disassembled an old engine I had to see how bad the case damage was. The left half needs more work than I want to work with.
issues
* pretty substantial lower crack
* the shift arm bearings have lost concentricity. the shfit arm can be pushed in and out of the lower bearing, but it takes some force
good
* all the bearings are still press fit. I removed the ms small bearing to inspect the case. the main bearing came out when the crank was pressed out (it was not looser).
* at basic glance, the gasket surfaces appear in good shape.
If no one is interested here, I'll put it on faceberg, but wanted to offer it here first.
usps priority calcs at $33. make an offer ($40?)
