Author Topic: LED Performance TRX250R Intake for Roll Design No Link Frame  (Read 35881 times)
Offline ledperformance
« on: August 15, 2013, 11:44:07 AM »
We have designed a high volume stainless steel intake for Roll Design TRX 250R. Because the stock intake isn't able to flow enough air for big bore cylinders.
[ATTACH=CONFIG]1404[/ATTACH]
This is a view through the air filter end of the intake.
[ATTACH=CONFIG]1405[/ATTACH]
Side view of intake with bolt on frame bracket.
[ATTACH=CONFIG]1406[/ATTACH]
The tube is oval so it clears the shock though out suspension travel.
[ATTACH=CONFIG]1407[/ATTACH]
We are building a limited number of these intakes. If you are interested please contact Arlan at 503-522-2465.
« Reply #1 on: August 15, 2013, 11:52:48 AM »
Holy wow,killer job guys!!!
« Reply #2 on: August 15, 2013, 11:57:16 AM »
Wow that is nice. Anything for a stock frame set-up?
« Reply #3 on: August 15, 2013, 02:28:51 PM »
Those look awesome!
« Reply #4 on: August 15, 2013, 02:57:59 PM »
He had something up on his facebook page awhile ago fora stock frame... pretty fair price too!
« Reply #5 on: August 15, 2013, 02:59:28 PM »
We build a hi volume intake for stock frame TRX and for the 4 strokes as well. That is one of our best selling items. It optimizes the intake track length, and improves air flow. On the stock frame 250R intake we form a velocity stack shape after the straight section at the carburetor mouth and then use a cone to step up to a large mouth air filter. This shape gives us a large plenum area to hold filtered air and the divergence of cone broadens the power band. The cone shape helps us maximize the intake volume in the space we have and organizes the air so it is coming straight into the mouth of the carburetor. We always see hp gains with this design. The more hp the engine is making the higher the gains.
« Reply #6 on: August 15, 2013, 03:01:23 PM »
Thank you!
« Reply #7 on: August 15, 2013, 03:14:37 PM »
Do you make one for a laeger framed/ CR500 link combo?
Looks sick.  Id like to have one to replace my stock intake boot.  Unfortunatly i would still want to use some sort of airbox.  running in mud is no bueno on open filters.
Offline Michael88R
« Reply #8 on: August 15, 2013, 11:33:56 PM »
Very nice.  Glad to see LED making new products for the TRX250R, especially something that is only for no-link set ups.  Even more impressive.
Offline enri330r
« Reply #9 on: August 15, 2013, 11:46:18 PM »
arlan very good job! they look great!
Offline Victork
« Reply #10 on: August 17, 2013, 01:10:00 AM »
Wow! Badass
Offline Allison#51
« Reply #11 on: August 17, 2013, 06:35:00 AM »
Wow very cool! I wish I could run without an airbox I'd be all over this.
« Reply #12 on: August 17, 2013, 02:00:31 PM »
We will probably add an air box to the intake this winter when we are not so busy.
« Reply #13 on: August 17, 2013, 03:25:15 PM »
Quote from: ledperformance;8942
Now we're talkin! This IS when I will buy one for sure! I just can't afford the chances of water with no box
Offline supernutt
« Reply #14 on: August 17, 2013, 03:44:36 PM »
Sign me up for one also for a CR500 link narrow Laeger frame with an airbox
