Author Topic: Kicker Knuckle (Sonny Fricia)  (Read 42729 times)
Re: Kicker Knuckle (Sonny Fricia)
« Reply #15 on: November 08, 2025, 09:15:49 PM »
Any updates on modifying OEM kickers to work with your knuckle?
As always thanks for the great parts!!!
Offline SFricia
« Reply #16 on: November 08, 2025, 09:26:03 PM »
Modifying the stock kickers was successful in my experiments. Any particular information you are looking for regarding that?
Offline ATVRacing2
« Reply #17 on: November 10, 2025, 03:02:00 PM »
Any updates on when the next batch of Kickers will be made by chance?
« Reply #18 on: November 10, 2025, 03:38:19 PM »
What’s the procedure as far as getting the oem fixed…exchange or do you get your kicker back with a knuckle?
Thanks
Offline SFricia
« Reply #19 on: November 10, 2025, 11:42:59 PM »
I true up the bore on the OEM kicker and oversize it. Then size match it to a knuckle with an oversized post.
I got the kicker and knuckles mated tonight. I take it back, the gold zinc looks amazing.
Offline SFricia
« Reply #20 on: November 10, 2025, 11:45:15 PM »
I don't quite know. I have a very large project that I need to finish before I work on any of my own stuff again unfortunately.
Offline ATVRacing2
« Reply #21 on: November 11, 2025, 08:34:00 AM »
Ok thanks for letting me know on that. When you are able to make the next batch, I am definitely interested in purchasing one from you.
« Reply #22 on: November 11, 2025, 08:05:19 PM »
I’m definitely interested in one or two myself
« Reply #23 on: November 11, 2025, 08:32:03 PM »
Sharing
First set is finished. Almost a year to the date from when I started designing my initial concept on the kicker to now. Several revisions to the fit, the profile, the overall shape, and countless updates to the detent mechanism.
Knuckles turned out fantastic as well. Overall, much more complicated than I first anticipated. I honestly should have known better since nobody else ever tried to reproduce them. It is amazing at how intricate and technical the OEM knuckle is.
Answers to frequent questions.
1) Kickers are made from a high strength aluminum. There have been no failures in testing from the riders and the feedback has been that they are much stronger than 6061 versions, the grip is excellent (no slip), and the wear is significantly improved. The retracted fit is a hybrid to work with OEM, Maier, and Fullbore plastics. All aftermarket plastics have deviations from OEM, but I tried to accommodate them as best as I could.
2) Knuckles are made from hardened 4140. Often referred to as "chromoly," is several magnitudes stronger than the factory component. Much harder (not too hard to cause brittleness), and much less prone to deformation. I forsee these surviving long after we are gone.
3) First batch is sold.
4) Next batch will be towards the new year. Many might be aware, but I currently have a very large project that I need to finish before I start working on any of my own stuff.
5) Knuckles will fit both my kicker and OEM kickers. Kicker will fit my knuckle and OEM knuckles.
6) If your kicker is worn out, I will offer a service to remachine your OEM kicker and provide a size matched aftermarket knuckle for you. This will restore your OEM kicker to new condition.
7) Future cost is uncertain due to the extreme volatility in the raw materials sector. An estimate will be roughly $200ea for the kicker and the knuckle. These aren't cheap. They weren't cheap to make, and they aren't cheap to continue manufacturing. They use some of the best possible materials available, and it required a significant investment in specialized tooling.
If you have an issue with the pricing, please be mindful and respectful of the time and monetary investment I have dedicated to the community. Knuckles.
8) I'll start pre-orders for a large batch run early December. You are welcome to message me now to get your name on the list and provide a deposit. Just be aware that I won't be starting them until my current backlog is cleared.
Offline ATVRacing2
« Reply #24 on: November 16, 2025, 03:08:40 PM »
Thanks Joe for sharing that. Sonny I sent you a PM
« Reply #25 on: November 16, 2025, 05:33:03 PM »
Yup no problem
« Reply #26 on: January 01, 2026, 05:49:58 PM »
Sharing
I will be starting on the next run of 250R kick start knuckles shortly, and one of the questions I have is regarding an option I was considering.
I was considering making an aftermarket knuckle that has an oversized pin (the connection pin that the kicker rotates on). Then offering a service where you'd send me your OEM kicker and I would machine the kicker to match this oversized pin on the aftermarket knuckle. Why this is a valid question is because the OEM kickers themselves get worn out, and the bores are no longer round and way past nominal dimensions. In other words, replacing an OEM knuckle with mine will not tighten up a wobbly OEM kicker, if that makes sense. Likewise, OEM knuckles wear out too, so putting one of my kickers on an OEM knuckle may also not fit tightly.
Is this a service or option some of you would be interested in, or is a stock geometry knuckle built to OEM spec. good enough? I know how fond some of you are to OEM kickers, and the hesitancy to move to an aluminum kicker is not something some of you want to do.
I ask because to do this, I would need to carry this custom knuckle in stock and I don't want to have to do that if you aren't interested. The time and money to make these parts is very extensive, so this isn't something I want to under or overshoot.
« Reply #27 on: January 02, 2026, 04:13:49 PM »
Sonny, I think it’s a great service.  I’d undershoot on manufacturing.  Make it a limited run a few times a year that way you’re not stuck with the oversize knuckles in stock.
