Author Topic: Puma tranny?  (Read 3111 times)
Offline ktm250r
Puma tranny?
« on: August 18, 2013, 09:46:07 PM »
I'm gonna start buying parts to build a puma engine soon for my ktm 2stroke conversion, looking for some input on what kind of tranny I should run, it's gonna be mostly for dune/trails/wot dirt roads and hopefully be built by led and in the 80 hp range maybe higher in the future, what do you guys think I should go with? Oem cyroed and backcut, Oem/Yukon cyroed and backcut, or wait for the billet Oem if it does ever happen?
Puma tranny?
« Reply #1 on: August 18, 2013, 10:01:23 PM »
Oem cyroed and backcut. Only need like 2nd gear back cut. If you are getting 100 HP then you might want to get billet. Tranny's are only $200. You can get 2 sets for the price of Yukons. They really aren't any better than OEM.
Offline ktm250r
Puma tranny?
« Reply #2 on: August 19, 2013, 12:10:59 AM »
Thanks for the reply, so back cutting the other gears are not beneficial at all?
Puma tranny?
« Reply #3 on: August 19, 2013, 12:46:50 AM »
Just the gears you use the most. Usually 2nd if you start in that gear when racing. Otherwise 1st and 2nd I believe. Most time damage occurs is the slip between first and second.
