Workshop
Engine and Bottom End
Atc clutch in an 88 trx 250 r
Topic: Atc clutch in an 88 trx 250 r (Read 2846 times)
wifespissed
August 19, 2013, 05:49:14 PM »
I hope one of you guys can tell me if a clutch from a 1985 atc 250 r engine will fit in a 88 trx 250 r engine. In other words are they the same thanks in advance
Lets go Red Sox!!!
fearlessfred
August 19, 2013, 06:31:52 PM »
as far as I know it will fit but the preasure plate and the type bearing used is different 85 came with a single large ball bearing that goes between the pushrod and puck.the 88 came with 3 small bearings that wore out very quickly and was updated in a kit that Honda sold fo 40 bucks the 89 came with the updated flat Torrington bearing
Pumashine
Supporting Member
Total likes: 27
August 19, 2013, 07:25:41 PM »
Yes, all the motors 85-89 are the same as far as clutch swapping. I moved your thread to the engine section where it should have been started, thanks!
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
wifespissed
September 02, 2013, 06:23:33 PM »
Well i got the clutch in today . The 86 setup went right in thanks for the input guys
Lets go Red Sox!!!
Workshop
