Author Topic: How to design a new suspension linkage  (Read 19678 times)
« Reply #30 on: February 06, 2014, 12:34:03 PM »
Just finished the video. Thanks, Andy, for making the video. I enjoyed it quite a bit.
I still can't help but think though, that the 450r swingarm could be adapted to run on the 250R using a new type link like you made. The geometries are not that different from one another. I just think it may take a custom made link and maybe a custom dogbone. I think this could play into the option of having an LT suspension for the rear.
Offline troybilt
« Reply #31 on: February 06, 2014, 02:17:10 PM »
Quote from: rablack21;24919
Agreed 100%, the conversions I've seen they just swapped swingarms and links and didn't actually try to figure it all out.  It may not take much at all, new link or something.  Someone just needs to put some effort into it.
With that said, I like my stock 250r linkage on the 89 better than the stock 06+ 450r linkage.  I just measured my 450 with MX tires and the pre-load set as low as possible (stock shock and link, mind you) the ass end (rear of seat) sticks up 1"+ taller than the 250r which has 20" tires...
Elsinore 496cc Saber
« Reply #32 on: February 06, 2014, 03:47:59 PM »
I wonder if GThunder made a new linkage for their 250R project? I know Laz put a 450r swing-arm on that project. I don't think he'd do it without doing it correctly.
Offline andy@maultechatv
« Reply #33 on: February 06, 2014, 04:51:14 PM »
The progression on the stock 250R link isn't bad at all from what I mapped out.  (It's really hard to do it on paper though due to measuring errors).  I'd like to get a string potentiometer hooked up with a program to calculate the changes but just haven't done it yet.  Or what would be better is to have the solid works program and do it on there but that's WAY out of my price range.
Offline troybilt
« Reply #34 on: February 06, 2014, 05:04:27 PM »
Andy I have solidworks and can do all of that.  I also have an industrial 3D scanner and I've scanned in Laeger frames, 250r frames, 450r frames, swingarms, etc... I can provide that leverage ratio and % rise in rate if someone is interested, I just haven't put too much time into as I didn't know if was warranted...
« Reply #35 on: February 06, 2014, 06:39:45 PM »
Quote from: troybilt;24947
I'd be very interested in seeing that.  I'd like to see a comparison graph of each.  I'll do some checking into a solidworks program and would be more than happy to do the foot work to make this if you'd be willing to share the frame scans.  I'd share my info here for everyone to see.
Offline troybilt
« Reply #36 on: February 07, 2014, 07:11:06 AM »
Quote from: andy@maultechatv;24956
Here is just a start of what I've done.
04-05 450R Frame Scan
Laeger 250R Frame CR500 linkage
How  I layout the suspension geometry, (as an example): The 3 lines  represent ride height (middle) max up travel and max down travel.   Up  travel set with 1" frame clearance, max down with 13" frame clearance  total 12" of travel
How I calculate suspension Leverage Ratio and % Rise in Rate, I have this for all styles of linkages.
« Reply #37 on: February 07, 2014, 07:44:07 AM »
I tried zooming in on that last page but it's too blurry to read.  Very interested
« Reply #38 on: February 07, 2014, 08:16:48 AM »
Andy - great video as always!
Troy - you just took this thread up a couple of notches - very cool stuff here!
Offline Langbolt
« Reply #39 on: February 07, 2014, 12:55:31 PM »
Troy - You've got all the really COOL toys!! That scan is AWESOME! This will really help our community really understand this topic - Thanks for taking the time in doing all that! :)
Offline MANIAK
« Reply #40 on: February 07, 2014, 01:47:31 PM »
Hmm.......... plasma cutter, CNC mill, tig welder, water jet, solid works....... doesn't everyone have these in their garage????
More like........ torch, drill press, arc welder, garden hose, crayons and paper, oh and can't forget duct tape and bailing wire !!!!
Offline troybilt
« Reply #41 on: February 07, 2014, 04:35:25 PM »
I'll post more details of this information as well as my calculations.  I just wasn't sure anyone was interested.  I love this stuff, :D
« Reply #42 on: February 07, 2014, 05:27:37 PM »
Quote from: troybilt;25053
Yeah Troy keep it coming!  Make sure some of the good technical stuff gets in the Tech Sections too!:redbull:
Offline rk88r
« Reply #43 on: February 07, 2014, 06:38:15 PM »
Very cool Troy.
\'88 265 pv peps
One other \'88
Offline bnau267
« Reply #44 on: February 07, 2014, 10:51:53 PM »
Awesome.  Clearly the gang likes the technical stuff.
