Author Topic: My long awaited 88 R project  (Read 8520 times)
Offline Texas30cal
« on: August 29, 2021, 11:58:57 PM »
I posted this in the introduction thread but I’m going to again here so anyone who reads has the whole story:
 just acquired my second 250r, it’s a 88, my first was a 86 I got new in 87 and was stolen in 92 😭. I’ve wanted one ever since. I got a brand new 92 quad racer but it didn’t do the trick for me so I sold it. Then I had a super clean 350x in 94 that I sold in 96 🤬 (STUPID)!! In 2004 I acquired 2 used cannondales cheap they’ve been great and still have them, but I finally got another R yesterday. It’s all there and pretty clean, not running, black plastic 👎 and some nice aftermarket parts. I pulled the engine today, and am making a parts list.... anyway, thanks for listening and I hope to learn and contribute as I’ve been working on atvs since 84, was a tech for 3 years, ran a service dept for 5 years, and now have my own shop for 10 yrs this month.
Yes, a buddy has had it for about 10 yrs, pic is still at his shop as I don’t have room. I finally talked him out of it, trading my labor building 2 guns for him , one Spanish cetme c and a mg42. Swingarm looks great, all rubber parts are soft with no cracking except for the shock bump stops.  Axle is rusty, has renthal bars, cannondale LT front end with elkas, aftermarket steering post with vibration dampeners, black plastic has no cracks , haven’t seen the seat yet it’s upstairs, also came with stock front end, itp front and rear sand tires, and Graydon proline nerfs
Offline Texas30cal
Re: My long awaited 88 R project
« Reply #1 on: August 30, 2021, 12:05:10 AM »
I didn’t get a pic before pulling the engine,  first pic is with the cannondale moto LT front end, second is after more disassembly and after installing the stock front end, next is wash and degrease, then sand the rusty spots and touch up. I don’t plan to try for a perfect restoration right away but while it’s nearly stripped I want to get the frame, and steering stem painted right.
« Last Edit: August 30, 2021, 04:23:58 PM by Texas30cal »
Offline Texas30cal
« Reply #2 on: August 30, 2021, 10:48:11 PM »
All cleaned/degreased , more parts stripped off, now to decide if I sand/touch it up or sandblast it. Also got some small parts blasted.
« Reply #3 on: August 31, 2021, 07:06:03 PM »
Bringing back memories of when I first got mine.
« Reply #4 on: August 31, 2021, 07:18:40 PM »
Looks like a very nice foundation to build off of.... Have you considered just cleaning & waxing the frame & leaving it alone other than that? The OEM paint on my wife's 86 frame was in pretty much the same shape as yours & since it gets ridden the most instead of making it all pretty I just degreased & waxed the factory paint & it looked pretty nice until after 6 years of dune riding its about time now to do it all over again.
Offline Texas30cal
« Reply #5 on: September 01, 2021, 12:47:41 AM »
I’d really like to make it look better, it won’t be ridden a lot and will NEVER be in the mud. It’s been touched up before as there is grey primer visible and the red touch ups wipe off easily with brake cleaner. I’m having trouble finding a 66.75mm piston right now.
« Reply #6 on: September 01, 2021, 11:11:18 AM »
Here's one. Looks like the only one available on ebay at the moment. Better buy it up quick:
https://www.ebay.com/itm/254899138373?hash=item3b592c2f45:g:D8AAAOSw2xRYRr4-
Offline Texas30cal
« Reply #7 on: September 01, 2021, 03:49:37 PM »
I looked and looked but didn’t see that one, already found one for $20 more 🤦‍♂️. Thanks anyway for the tip!
Offline Texas30cal
« Reply #8 on: September 07, 2021, 10:04:15 PM »
Lots of progress here , frame is stripped, a couple of small repair welds to clean up and it’s off to the blaster.
« Reply #9 on: September 07, 2021, 10:32:41 PM »
I love seeing stock framed R’s being redone.  Thanks for posting your progress.  Can’t wait to see it finished.
Offline Texas30cal
« Reply #10 on: September 07, 2021, 10:53:29 PM »
Thanks, I will keep posting, I’ve got more. I think all engine parts are here , crank, piston, gaskets, seals, all new trans/balancer bearings and all but one of the cases are bead blasted and painted. I went today to check on the Ford race red for the frame, for 1 qt of paint with reducer and hardener and 1 qt of epoxy primer with reducer snd hardener they wanted over $400 😳. I’m going to try one other place and if it’s that high it’s going to get the pj1 88-89 Honda red.
Offline Texas30cal
« Reply #11 on: September 07, 2021, 10:58:08 PM »
From what I remember the head/cylinder on the 88-89 were bare but not dull like bare blasted aluminum like the cylinder in my pic. On the cylinder head I used a bronze brush by hand to knock the rough surface down. I think this is the way I’m going to do it with a coat of VHT clear to prevent the bare aluminum oxidation.
« Last Edit: September 07, 2021, 11:01:56 PM by Texas30cal »
Offline traxman
« Reply #12 on: September 08, 2021, 02:31:56 AM »
You can also use plasticote cast aluminum caliper paint. It’s high temp cleans oil and gas off of it easily. I’ve had it on cylinders for years and it looks new still. But it’s not it’s very easy to re-coat it and make it look brand new again.
Offline traxman
« Reply #13 on: September 08, 2021, 02:41:34 AM »
Another picture.
Offline Texas30cal
« Reply #14 on: September 08, 2021, 08:46:51 AM »
Looks good👍
