Author Topic: rear shock ressi clamp att:pumashine  (Read 5976 times)
Offline trx250scar
« on: September 02, 2013, 07:35:32 PM »
a while back we had a thread going  about making some of these ressi clamps. were did this end up? i currently have removed all the oem mounting brackets off of my 88 oem frame and am in need of this pretty bad
Offline The Phantom
« Reply #1 on: September 02, 2013, 08:00:13 PM »
I also may entertain the thought of buying a set of 3.  I like to shop with my eyes though.
« Reply #2 on: September 02, 2013, 08:55:53 PM »
What frame, the stock frame has clamps. The ones I made were for the front. Ryan should have got them by now. What resi were you using?
Offline GO OVRIT
« Reply #3 on: September 02, 2013, 09:43:15 PM »
I'm in need of a pair too.  Fronts, oem frame, tcs shocks.  They look just like the rear stock resevoir.
Offline trx250scar
« Reply #4 on: September 02, 2013, 09:52:52 PM »
i need one for the rear oem ressi oem chassis as i removed all the oem mounting parts for the rear ressi
« Reply #5 on: September 02, 2013, 09:56:33 PM »
Every resi is a different diameter. When some one comes up with a universal design I will make lots. I made 2 sets for Jons PEP rezies. Shipped the same set to rablack21 and they were a 1/4" too big.  Had to remake the whole set. So I will need to know the exact diameter of the resi and which frame member you are attaching to.
Offline trx250scar
« Reply #6 on: September 02, 2013, 10:16:22 PM »
ok i will get you some numbers. thanks for your attention to this
