Author Topic: what cylinder is this  (Read 5172 times)
« on: October 27, 2013, 01:21:19 AM »
trying to find more info about it but i cant determine what model it is or what engine it was used on
Offline Bigred
« Reply #1 on: October 27, 2013, 12:38:02 PM »
Polaris or maybe a meugan cylinder would be my quess
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Bigred
« Reply #2 on: October 27, 2013, 12:38:47 PM »
Or a old sled cylinder
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline The Phantom
« Reply #3 on: October 27, 2013, 04:31:14 PM »
Rotax is used by Bombardier or skidoo.. not sure about other manufacturers
« Reply #4 on: October 27, 2013, 05:05:15 PM »
seems rotax made engines for all kinds of stuff. thats why i cant find exactly what cylinder this is
« Reply #5 on: October 27, 2013, 06:05:36 PM »
Rotax is part of BRP - Bombardier Recreational Products which so is Can-am, ski-doo, Sea-doo and  others
Offline jfwyatt1
« Reply #6 on: October 27, 2013, 06:28:56 PM »
Quote from: rsss396;15888
+1  one of BRPs  engine casting plants is located about 10 miles from my house i have a few friends that work there ill show this pick to them and see if they know what its off of.
« Reply #7 on: October 27, 2013, 09:28:31 PM »
I remember years ago that the american made ATK dirtbikes had rotax engines in them. Also my friends dad has an ultralight plane with a rotax in it.
« Reply #8 on: October 28, 2013, 12:44:20 PM »
It's definitely off of a SKI-DOO....Measure the BORE and that will narrow down your search quite a bit.
It's a Case reed inducted motor.....which narrows it down further (so it's not a 700 or 800)
Does it have a RAVE valve ?
Try looking on E-bay for a ROTAX cylinder.....you might find the same one and it'll have what it came off of in the Description.
Offline 250rnut
« Reply #9 on: October 28, 2013, 01:12:17 PM »
That is an Aprilia RSR 125 Cylinder. Send me my prize. :joyous:
« Reply #10 on: October 28, 2013, 08:08:07 PM »
its not my cylinder but rather a pic i found. i had a hunch it was the rsr but couldnt confirm it because there seems to be some many darn rotax on various engines. reason i was inquiring about the pic is because i thought i saw a rotax jug with similar porting to the rsa. is the rsr very similar to the rsa ?  wanted to see what bore it was and if it could fit on ktm 300 cases but if its 54x54 then obviously that aint gonna work. hoped it might of been from a 250cc engine
