Author Topic: 496 saber build  (Read 15175 times)
Offline johnny22
496 saber build
« Reply #30 on: December 09, 2013, 09:10:07 PM »
Quote from: troybilt;19543
Nitrous, or fuel pump... is what I was told.
cool thanks troy.
Offline johnny22
496 saber build
« Reply #31 on: December 09, 2013, 09:11:48 PM »
i also noticed that it barely clears the frame with the lectron on there. Its gonna be a tight fit when i go to put the intake on there.  What does the cast cpi bowl cost?
496 saber build
« Reply #32 on: December 09, 2013, 09:45:22 PM »
Quote from: Polonda;19560
Not that I'm aware of.  Not sure a need exists for one actually.  The huge cast cowl is not needed until you get into the big Lectron carbs where lots of Alky is needed.
Thanks for the pics and info.. was interested in one on a PWK for big hills.
Quote from: atv fan 28;19566
Im running the UPP boot and cast bowl on my Cutler carb. Mine clears the case but not by much. The Tyson frame i have was running a Puma with a Lectron carb. But with my Saber and the Cutler i had to cut the shock mount tube and move it back.
Good to know Wayne.
Offline atv fan 28
496 saber build
« Reply #33 on: December 09, 2013, 09:47:27 PM »
Quote from: johnny22;19572
around $200 i believe
Offline Morse250r
496 saber build
« Reply #34 on: December 10, 2013, 06:10:34 AM »
Make sure you have enough room between your frame and carb I broke a power jet off once in the dunes and had to move my cross member back to avoid it.
88 rb racing duner
Trx 70\'s
Atc 125
