Author Topic: bore size ?  (Read 3080 times)
Offline kevin wcmo
bore size ?
« on: January 21, 2014, 05:01:59 PM »
on a 86 jug with the extra thick sleeve installed with the stock 86 length rod, what is the max bore on these?  i have seen pistons up to 69.5, but i thought i have seen builds with a 72mm bore on a stock looking jug.  is that right?  and if so, what pistons are they using?  thanks
Offline kevin wcmo
bore size ?
« Reply #1 on: January 21, 2014, 08:43:21 PM »
is the sleeve that is required to be relieved for the head studs considered a bb sleeve?  if so, where is a source for the pistons?  thanks
bore size ?
« Reply #2 on: January 22, 2014, 06:52:11 AM »
The 72mm stock cylinders have custom sleeves installed in them. LA sleeve can do this but these are very prone to head gasket failure, not that they can't work but a new ESR cylinder is a much better investment.
